38 Offset?
Old Dec 5, 2007 | 07:14 PM
k_h_d's Avatar
k_h_d
38 Offset?
What is the range of offset that can fit on a Mini? Would a 16x7.5 offset 38 work?
Old Dec 5, 2007 | 07:56 PM
user 7082082's Avatar
user 7082082
I am running 38 offset with 15s . Currently running 205/55 and upgrading soon to 225/50. No problems here.
Old Dec 6, 2007 | 12:21 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Compared to stock 16" wheels and tires-
16x7.5" with +38mm offset will be OK. About +36 to +40 mm offset in that width will work if you use tires of about stock tire diameter or less for best clearance.
Trouble comes from lowered suspension which can reduce clearance in the rear. Once rims get wider than about 7.5" then offsets of +40 to +45mm risk rubbing on the rear lower trailing arm so either spacers are needed or offsets of about +36mm or less.
Best tire size for you would be 205/50-16 which fits 16x7.5" rims or
225/50-16 but with stock suspension (it's taller than stock at 24.7")
Old Dec 6, 2007 | 07:15 AM
Diploman's Avatar
Diploman
I'm running 16 x 7.5 OZ Ultraleggera's (ET 37) with 205/50/16 non-runflats. No clearance problems.
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
