Rust After Washes
Old Nov 25, 2007 | 06:16 AM
checkercoop's Avatar
checkercoop
Rust After Washes
I was wondering if anyone had any good solutions to these rust problems after washes.
After was rims rust develops. Once you drive and use the brakes most is gone, but there is still some at the ring around the top where the disks connect and the brakes dont touch. Any solutions?
Also after spraying the front, it gets in the grill. I've noticed some water marks on my radiator which i dont want to turn into rust in a few years. I hope theres a different solution than taking the front grill out every time to wipe it clean and dry.
Thank you
Old Nov 25, 2007 | 07:10 AM
Bhatch's Avatar
Bhatch
Radiator is aluminum, it doest not "rust" it pits..which is still oxidation and the moisture in the air will do that anyway.
The rust on your discs is normal and completely ok, just brake a few time before you get on the motorway.
Old Nov 25, 2007 | 09:34 AM
Minidrivr's Avatar
Minidrivr
If the hub of the disc is rusting you could paint it with caliper paint. The other option is some cross-drilled Zinc coated rotors.
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
Scm68
Jan 27, 2016 12:33 PM
vulkandino
Oct 31, 2015 08:29 PM
minieater
Oct 28, 2015 02:15 PM
