For next spring I am looking at summer tires.
Old Nov 21, 2007 | 10:21 PM
r56mini's Avatar
r56mini
I will be using my all season 16" OEM set up for the winter. But I have a set of S lites for the summer/track. And I would like a Max performance-Extreme performance summer tires on the S lites. I searched for the OEM size 205/45/17 at tirerack.com and the choices are extremely limited. There are more options if I go with 205/40/17 or 215/40/17. Will I have an advantage in handling if I went with the lower profile (205/40/17) instead of the OEM size or 215/40/17? Or would you just go with 215/40/17 for the extra contact patch?
Old Nov 22, 2007 | 05:54 AM
84im's Avatar
84im
Try here
http://www.tires-easy.com/start.html
Old Nov 22, 2007 | 08:09 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
www.edgeracing.com has many of the big name high performance tires that tirerack doesn't carry (like toyo, or falken for example)
The sidewall difference will only be 1/10th of an inch, and the contact patch won't be much wider. I think the handling change would be minimal with whichever you chose. The 205/40/17's will also have better gearing than the 215 to aid in acceleration at a slight lose of absolute top speed (which is limited already at 135 or whatever the r56 is limited at). The 205's might also weight a tiny bit less which would be nice
I'd stick with the 205's cause in my opinion, they offer more pro's. They'll look better, the sidewall is shorter, the gearing is better, the weight and distribution is better, and the price is probably better .
Old Nov 22, 2007 | 08:19 AM
Alex@Helix's Avatar
Alex@Helix
At the same time, wouldn't the advantages in gearing/weight be very minimal?
If the setup is predominately for the street, I don't think you will really notice the difference. At the track, the extra contact patch might help you better then a minimal weight or gearing advantage. I would look for tires in both sizes and buy the best tire for your budget.
Old Nov 22, 2007 | 08:21 AM
Rally@StanceDesign
Yes....most likely very minimal. Either way you go with the tires, I'm sure you'll be happy. But if you list all the (minimal) pro's, it might help with the indecision.
Old Nov 22, 2007 | 08:24 AM
Alex@Helix's Avatar
Alex@Helix
Very true.
Old Nov 22, 2007 | 10:34 AM
r56mini's Avatar
r56mini
Originally Posted by 84im
there are sooo many cheap tires!
Which tires are the stickiest among the ones below $100?
Old Nov 22, 2007 | 10:35 AM
Bhatch's Avatar
Bhatch
ECSTA MX KU15205/40 ZR17 84Y RF BSW
Old Nov 26, 2007 | 08:35 AM
leo@edgeracing.com's Avatar
leo@edgeracing.com
r56mini:
You can check for the Falken FK452 or the Falken RT615. Personally, the FK452 will give you a more comfortable ride with good wet and dry traction. Plus, the tire is very quiet. The RT615 is all out performance and will grip much better than the FK452 in the dry. The wet traction is not as great and it is a loud tire. These tires are both under $100 each. Let me know if you have any questions.
Leo Barrios
leo@edgeraciong.com
800-489-5353 x211
http://www.edgeracing.com
smdmini
Oct 7, 2019 06:05 AM
1ZigZag
11
Nov 22, 2015 07:42 AM
nashvillemini
Sep 30, 2015 10:26 PM
massmini03
Sep 18, 2015 05:40 PM
PelicanParts.com
Sep 16, 2015 12:27 PM
