Drivetrain COOPER PULLEY ON COOPER S??
I seen in a website Webb Motorsport and Craven i think that has weight comparisons of crank pulleys between aftermarket and oem MCS: pre 04 (7lbs), post 04 (5lbs), AND "Cooper pulleys (3lbs)" or smething like that not sure if thats right.
BUT my question is the crank pulley on the Cooper fit the Cooper S?? Is it possible?
The crank pulleys should be the same - can't imagine how the Cooper's could weigh that much less. The only differences I know of are the internals and the water pump. That, and were it the case, there would have been a run on Cooper crank pullies by now.
heres one of them:
http://www.mossmini.com/Shop/ViewPro...eIndexID=64235
heres another link bringing up the same question, but no clear response.
http://www.mini2.com/forum/engine-dr...er-pulley.html
Think of attaching a 1 lb weight to the tip of a ceiling fan's blade. The fan is OBVIOUSLY going to be way off balance, spinning wildly (Please DON'T try this). It might even fall out of the ceiling. Now take the same 1 lb weight and attach it to the interior blade attachment point (The little brass "Arm" that sticks out of the motor hub), it might wobble a bit, but not even close to the previous example.
The placement of said weight in relation to the point of rotation is a lot more important than any minimal weight reduction.
Another consideration is one of durability. MINI made the crank pulley the weight it is for a reason (Harmonic balancing, etc). Hell they even lightened it a little for MY2005 (presumably because they found the weight excessive). Don't you think they would have just used the "Lighter" Cooper Pulley if it showed any performance benefit?
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
