R56 Any issues with 17x7.5 +45mm Rotas?
Old Nov 15, 2007 | 07:59 AM
Bishamon's Avatar
Bishamon
I'm considering buying some 17x7.5" Rota Subzero wheels with +45mm offset for my R56 MCS. Will there be any issues with rubbing on stock suspesion? I'm concerned about the 7.5" width. I plan on equipping some 205/45R17 runflats, but I haven't decided on the specific tire.
Old Nov 15, 2007 | 08:01 AM
Msteadman's Avatar
Msteadman
Hey, Bishamon. Try reposting here and you should find a ton of info.
Best of luck
Old Nov 15, 2007 | 08:24 AM
Bishamon's Avatar
Bishamon
I considered posting there, but I wanted R56-specific information, so I figured this was my best bet. Still, I may have been wrong...
I think we really need a 2nd gen-specific wheel and tire section.
Old Nov 15, 2007 | 08:29 AM
LuxoDave's Avatar
LuxoDave
I like the Rota Subzeros. I had them on a previous car.
I can't answer the fitment question though. :(
Old Nov 15, 2007 | 08:33 AM
Msteadman's Avatar
Msteadman
Valid point - it's kind of strange as we have R56 specific threads on just about everything except for wheels/tires. However, as long as you specify in your post that you have a 2nd gen MINI, you're still likely to find the majority of information there. Keep an eye out for member minihune. He's often signed on and can be of great assistance for literally anything wheel/tire related.
Old Nov 15, 2007 | 08:50 AM
Bishamon's Avatar
Bishamon
Thanks for the info. I will post in that section as well, and hopefully I won't get in trouble for cross-posting.
Old Nov 15, 2007 | 11:01 AM
r56mini's Avatar
r56mini
205 mm width will be probably OK. I felt the gap between the front tire and the shock and my index finger filled the gap. That means there is barely 10mm of space. If the stock offset is 42 and you go any higher, the wheels will be closer to the shock by the difference. If the tire is 10 mm wider than stock the tires will be 10mm/2=5mm closer to the shock. I don't know what OEM 17" offset is.
Old Nov 15, 2007 | 12:46 PM
kyriian's Avatar
kyriian
if you need more info you can ask me
i have a 1st gen, 205 is fine, but 215 you might consider a set of 5-10mm spacer in the front as it starts to rub a teensy bit on the inside
btw, they are discontinued by rota, so looking for a set might prove difficult
i have a set right now that i am gonna run on the track
Old Nov 15, 2007 | 01:24 PM
-Vampyre-'s Avatar
-Vampyre-
i thought mach V dan had rotas 17x7.5 with 45et and he had 235 40 for tires
Old Nov 15, 2007 | 01:25 PM
-Vampyre-'s Avatar
-Vampyre-
and oem offset is 48 or 50
Old Nov 15, 2007 | 03:11 PM
curtis0407's Avatar
curtis0407
I posted this in the Wheels and Tires section earlier today...
I have 17" x 7.5" +45 Rota RBs with 215/45R17 tires and haven't experienced any rubbing whatsoever. So far. I know the wheels are different - but the spec is the same so I don't think you will have any issues with the Subzeros - if you can find some.
Old Nov 15, 2007 | 03:13 PM
kyriian's Avatar
kyriian
the issue wont be the wheels i think, it will matter with the tire's shape, some tires have a more squareish profile, and at which will likely rub more
Old Nov 15, 2007 | 06:49 PM
Mach V Dan's Avatar
Mach V Dan
This is true. I run 235/40R17 on 17x7.5" Rotas (two sets so far), with little or no rubbing.
--Dan
Mach V
FastMINI.net
Old Nov 15, 2007 | 06:51 PM
r56mini's Avatar
r56mini
Those wide tires would make my car tramline right out of my lane in WA/OR.
Old Nov 15, 2007 | 06:52 PM
Mach V Dan's Avatar
Mach V Dan
Originally Posted by curtis0407
...I don't think you will have any issues with the Subzeros - if you can find some.
We can get some. Contact me for info.
--Dan
Mach V
FastMINI.net
rtk90
Aug 29, 2019 09:08 AM
Sep 1, 2015 04:02 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
Dashdog
Aug 10, 2015 06:17 AM
