R50/53 what do i have to be ware when i remove the upper grill and bumper?
hey guys....instead of mini dealer..is there any other place that i can buy the nuts and washers for the upper grill...and some washer for the front bumper?
i m going to replace the grill with aero grill, but i m scare
that i will break the nuts . since i heard that there are alot "one time" nuts ,and washer on MINI.
How much will it cost and where can i get them?
Is there any difficulites with putting back the upper,lower grills and bumper?
please,give a hint...thanks
that i will break the nuts . since i heard that there are alot "one time" nuts ,and washer on MINI.How much will it cost and where can i get them?
I replaced my grill and bumpers with S ones. One thing I found was, with removing the grill, use a small flat-head screw driver to gently pry upwards on the under side of the nuts as you turn them. You should be able to re-use them. I re-used them all.
Aug 19, 2015 12:51 PM
I_drive_slow
Aug 18, 2015 10:47 AM
