R50/53 Maintenance
Old Nov 13, 2007 | 10:46 AM
grillhands's Avatar
grillhands
Maintenance
How do you reset the maintanence mileage countdown on the speedometer?
Old Nov 13, 2007 | 10:47 AM
Loony2N's Avatar
Loony2N
Either sand or a shotgun.
Old Nov 13, 2007 | 10:56 AM
BWROOFCHEX's Avatar
BWROOFCHEX
This procedure will work for models between 02-06
Maintenance Required Lamp/Indicator: Service and Repair
Resetting the Service Interval Indicator
The SII can be reset using the trip odometer reset button in the instrument cluster:
-- The ignition key must be in the "0" ("off") position
-- Press and hold the trip odometer reset button in the instrument cluster and turn the key to the "1" (accessory) position.
-- keep the button pressed for approx. 5 more seconds until the current SII status appears in the display: "oil service" or "Inspection". Release the button.
-- Press the button again and hold for approx. 5 seconds to change to the reset mode. The letters "RST" appear. While the display is flashing, press the button briefly to reset the service interval. The Interval will be displayed for 5 seconds.
-- Release the button and turn ignition off.
sometimes this can take more than one try.
Old Nov 13, 2007 | 12:12 PM
grillhands's Avatar
grillhands
You are the man BWROOFCHEX
Sep 10, 2019 09:22 PM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
Sep 10, 2015 11:55 AM
ronn
Sep 9, 2015 07:12 PM
