Drivetrain ZEX nitrous air filter? 75hp gain?!?!
Okay...to start off i'm not a ricer, but I am looking for some not-to-expensive-go-fast parts for my MCS. Has anbody heard of this.
I saw it advertised in this months Motor Trend. What do you guys think of this mod? Personally I wouldn't mind the benefits of an extra 75hp for about $100, but I have heard horror stories of engine blocks cracking and fuel rails exploding from NOS.
_________________
Mel A.
just a warning...you're talking to a 18 year old
2003 Mini Cooper S (DS, packages 1,2,3, HK)
1995 Land Rover Discovery (for sale)
1974 MGB
_________________
Mel A.
1974 MGB
As I understand it, a dry (only uses No2, no gas) system like this should only be used with a naturally aspirated engine. A forced induction engine like on the S would require a wet system (No2 +gas sprayed together) sprayed into the intake manifold directly.
Most wet kits run about $500, but can add up higher than that quickly for things like bottle warmers ($200ish), remote valve openers ($250ish) or digital control of onset percentages ($1000+).
R
R
You don't have to use a wet kit because the car is forced inductions. The wet kits are just a lot safer because you're injecting extra fuel as well and it will prevent a lean condition. There were guys with 1.8t's running dry kits and still making good power, the wet kits just made more of it.
Mike
Mike
polotska
Aug 23, 2015 09:10 AM
Aug 21, 2015 08:44 AM
