R56 Unreadable Dipstick
Old Oct 30, 2007 | 07:34 AM
VeryRedMCS's Avatar
VeryRedMCS
Unreadable Dipstick
Could someone give me the MINI part number for the special light needed to read the R56 dipstick? I know they must have one, as the human eye, with conventional lighting, can't read the danged thing!!! (perhaps once the oil gets really dirty)
Please don't say it's just me...
Old Oct 30, 2007 | 08:06 AM
korby's Avatar
korby
I agree ,try a white cloth ,pull it out and lay it on the cloth in the palm of your hand .
Old Oct 30, 2007 | 09:35 AM
MINIxB's Avatar
MINIxB
What's the dipstick look like? (sorry just curious. I don't have a new mini)
Old Oct 30, 2007 | 09:49 AM
TrboKrt's Avatar
TrboKrt
Looks like a tightly wound spring all the way from the handle to the tip with a metal ring clamped at the oil level mark and a pointy tip. As the oil gets dirty its easier to see on the dipstick.
We could always add dye to the oil.
Old Oct 30, 2007 | 09:54 AM
Robin Casady's Avatar
Robin Casady
Pull the dipstick out and lay it on a paper towel. Roll it a little so you can see where the stain lines up with the marks on the dipstick. Use the paper towel to wipe the dipstick clean. Return it to the engine.
Old Oct 30, 2007 | 09:59 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Wow - that sounds even worse than the 1st gen MINI stick - which is TERRIBLE....
Old Oct 30, 2007 | 10:43 AM
flav's Avatar
flav
it is.
Old Oct 30, 2007 | 11:53 AM
Loony2N's Avatar
Loony2N
Besides what Robin Cassidy said, another trick is to not try to read the stick while holding it nearly horizontal (as is normally done). After removing it, wiping it and reinserting it, pull it out just to the point where the "arrowhead" is visible at the top of the tube. Keeping the stick nearly vertical, look down it and you can see where the oil covers the rings on the stick. Once you get used to it, it's very easy.
Old Oct 30, 2007 | 11:55 AM
Robb's 07 Red MCS's Avatar
Robb's 07 Red MCS
What I did was take a black magic marker (permanent) and colored in the area between the low and high marks. I can read the oil a lot easier now than before.
Old Oct 30, 2007 | 03:16 PM
rockridge's Avatar
rockridge
I guess I am in trouble. I have 1300 miles on the car, and the oil is dark enough to make it easy to read.
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Mar 3, 2017 06:29 AM
GAT
Oct 21, 2015 02:12 PM
lifeofjenn
19
Sep 24, 2015 11:01 AM
WayMotorWorks
Sep 21, 2015 09:28 PM
