Kosei KS T1 Wheels
Old Oct 29, 2007 | 12:09 PM
Rennfahrer555's Avatar
Rennfahrer555
Kosei KS T1 Wheels
Hey everyone, I'm still in the market for wheels and I think I found the lightest cheapest wheels at this point. Kosei KS T1s weight 14.1 or 15lbs each depending on who you talk to. The OZ ultraleggeras are awesome but I would rather spend my money on good tires than pricey wheels (is that a good strategy?) The huge advantage with these wheels is that theyre a prefect fit so I dont need to mess around with hubcentric rings which I heard can be a handful. anyways I have a couple of questions
1. Does anyone have pics or reviews? ( I heard that these have trouble taking potholes)
2. Does anyone know something that can compete with this wheel at around this weight and price range? I know 5Zigens make a 5 spoke rim thats around 15lbs. I like the looks of Racing dynamics Pro race 1 and 1.5 but I am not surre how much they weight/cost.
3. What are the advantages of having two valve stems? Or does anyone know why that is done?
Any help would be greatly appreciated! Thanks everyone
Old Oct 29, 2007 | 02:32 PM
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by Rennfahrer555
...3. What are the advantages of having two valve stems? Or does anyone know why that is done?...
I was about that too. As it was explained to me, that way you can put air in (or out) one valve while checking the pressure with the other - saves time in racing?
Old Oct 29, 2007 | 03:14 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
It's actually so you can switch from oxygen to nitrogen
Old Oct 29, 2007 | 04:34 PM
bean's Avatar
bean
actually you are switching between air and nitrogen.....
Old Oct 29, 2007 | 05:08 PM
glnr13's Avatar
glnr13
all wheels have trouble taking potholes
Team Dynamics are 15 lbs at 17" and $178 a piece at webb motorsports. shop around tho... i got mine for $500 used.
fill the tire with nitrogen and release the other valve so that all oxygen is pushed out by the nitrogen. this way there is 100% nitrogen vs. mixture of nitrogen/o2.
is there an advantage to having nitrogen filled tires? more so for racers than daily drivers.
Old Oct 29, 2007 | 05:21 PM
Rally@StanceDesign
yah you're right....good call
Old Oct 30, 2007 | 12:07 PM
Alex@tirerack's Avatar
Alex@tirerack
Nitrogen offers stability. Oxygen combines with ever present hydrogen, allowing moisture in the air chamber. Deny the O - loose the moisture - more stable tire pressure across the temperature spectrum.
Your spring Vs fall tire pressures should remain more even.
No wet, no increase in pressure with heat!
Old Oct 30, 2007 | 12:16 PM
trackster's Avatar
trackster
I had a set of Kosei's awhile back and they worked out well. Nice and light and a good value for the price.
Old Oct 30, 2007 | 12:29 PM
minimusprime's Avatar
minimusprime
do they fit over stoptechs?
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
