Aftermarket wheels - do NOT use TPMS!
Please correct me if I am wrong...
If we do NOT use runflats, we should NOT use the new direct TPMS...
Because if we get a flat (imagine half way up the Taconic, or 89N in Vermont when it is -20 just after midnight when cell signal is poor) we will NOT be able to use Slime, and manual puncture is probably not an option...
Unless we are prepared to carry a "spare", for example a 15" Konig Feather from Altamini (or may as well order an identical 5th tire/wheel), which means seats down in the back.
Dealer says TPMS warning light will stay on but other warning lights will continue to function.
Any other options?
Any other options?
I wouldn't want a continual warning light. I was told by Mike at Tirerack that the TPMS would take the slime but would likely trash the sensor. I'd rather keep the TPMS, keep the slime, and risk replacing a $60 part in the unlikely event of a flat that cannot be fixed by a dynaplug.
Did you catch the post with the link to the Slime site saying that Slime CANNOT enter the tire because of te sensor?
Dyna plug is definitely a WARM, sunny weather option.
I thought that the TPMS in the 07 MCS did NOT use an in-wheel sensor. I was told that the ECU monitors rotational speed of each wheel and uses difference in the rotational speed to indicate a low-pressure situation. Is this not correct? I'm getting new wheels and tires this week and was planning on carrying slime and a compressor.
See: https://www.northamericanmotoring.co...d.php?t=115574
Federal mandate went into effect 8/31. Any vehicle sold in the US has to have a TPMS that senses individual tire inflation pressures. The easiest way to do this is the direct TPMS that take the place of the valve stems.
Dec 23, 2015 10:36 AM
ltjpunk7
Sep 6, 2015 07:32 AM
Aug 21, 2015 11:25 AM
