R52 Roof squeaks while opening, closing - any fixes?
Old Oct 21, 2007 | 03:52 PM
ronmichael's Avatar
ronmichael
Anyone have issues where the roof squeeks a lot mostly when closing but sometimes when opening? I just had it in to the dealer on Friday (two days ago) and they lubed it, but it didn't seem to last long. This is exactly what happened when I tried to lube the top myself - it only stopped the squeaking for a very brief time.
Any suggestions?
Old Oct 22, 2007 | 03:33 AM
cg1's Avatar
cg1
I don't have my mini yet - but my previous convert's made noises periodically. I used a silicone spray....worked real well and lasted a while too
Old Oct 22, 2007 | 06:19 AM
PuppetMaster2u's Avatar
PuppetMaster2u
Mine sqeaks like crazy too when opening/closing. If there IS anything to put on it I'd try it, but I assumed it normal?
Old Oct 22, 2007 | 06:40 AM
ronmichael's Avatar
ronmichael
I've tried silicone-based lubricants on it and they didn't last more than a day... I was thinking maybe the dealer would hit some points I missed but I guess not.
Old Oct 22, 2007 | 06:47 AM
buzzsaw's Avatar
buzzsaw
Same here until I used STP by applying it with a toothbrush. It has the best durability the of many lubricants I have used. It is also clear and doesn't muck up the mechanism. Works well-lasts a long time.
Old Oct 22, 2007 | 09:19 AM
The Red Wolf's Avatar
The Red Wolf
Mine makes a racket, as this is the first cabrio I've ever owned, I just assumed it was normal. Just a few responses so far, is that the consensus that are fairly noisy?
Old Oct 22, 2007 | 01:33 PM
homerwest's Avatar
homerwest
My original top was pretty quiet, but mine was replaced at 1ok miles due to white wear spots, and has been pretty noisy since. Kind of a high pitch squealing noise....
Old Oct 22, 2007 | 03:06 PM
Dr. Pepper's Avatar
Dr. Pepper
Mine only sqeals when I leave it down overnite or longer. If I raise it at the end of each day it's very quiet. You might try graphite powder lubricant. It's old school but effective on a lot of machinery.
Old Oct 22, 2007 | 06:42 PM
neilgj's Avatar
neilgj
My experience has been similar to Dr. Pepper's. When I leave the roof down for a long while it squeals like banshee as I raise it but subsequent lowerings (and raisings) are quieter until I leave it down again for a time. It's almost like it sort of lubricates itself...
Old Oct 23, 2007 | 06:01 AM
Hooptee's Avatar
Hooptee
Mine also squeals a lot. I haven't found a pattern yet, but Dr. Pepper and Neilgj may be right about leaving the top down a long time.
Old Oct 25, 2007 | 09:05 AM
havnap's Avatar
havnap
Coordinator :: Metroplex MINI
That's when mine squeaks but if I put it up and then back down no squeaking.
Just another quirk that makes it uniquely MINI.
Dec 23, 2015 10:36 AM
skippermini
Aug 13, 2015 06:13 AM
Aug 12, 2015 01:24 PM
