??? about R56 wheels on 05 MCc
Is there nothing out there that would allow an R56 set of wheels (14mm bolt holes) work with the 12mm bolts on my 05 MCc? I can't imagine there's not some sort of insert.
I really want to put my 16" Bridge Spokes take-offs on my 05 MCc I assume that there would be some movement on the R56 wheels if I used the 12mm bolts.
To my knowledge R56 wheels with 14 mm holes will work on all R50 and R53 Minis with 12 mm studs or bolts.
Perhaps Alex at the Tire Rack or a Mini service tech can verify that for you. The service techs that I have talked to see no problem with this fitments.
I believe there are conversion kits, Texas Speed Works, to go from 12 mm bolts to 14 mm studs if your concerned.
The wheels are hub centric, to align, and the bolt holes are dished, for compression, and the wheel is held in place by the hub and the dished part of the studs or bolts not the thickness of the studs or bolts.
Bolt them on........enjoy the drive!
Hope this helps...
Hope this helps...
Yep - you're fine. All of the MINI factory wheels have ~16mm bolt holes, so they'll work with either the old 12mm lugbolts or the new 14mm bolts.
Some people (like me) have used 14mm-12mm conversion studs in order to fit *aftermarket* wheels that don't have bolt holes big enough for the new 14mm lug bolts, but if you're wanting to use factory wheels from a newer MINI on your '05, they'll all work.
thebordella
Aug 31, 2015 01:37 PM
trw92a
Aug 26, 2015 01:47 PM
