Suspension H&R R53 Springs on a R50
Old Oct 19, 2007 | 12:21 PM
CHDesign's Avatar
CHDesign
Hey guys from what I can tell these springs are the same for the MCS and the MC. I just bought a set from a fellow boardmember I am just confirming this.
Old Oct 19, 2007 | 08:28 PM
Wake|MCS's Avatar
Wake|MCS
Yep they're the same
Old Oct 19, 2007 | 08:44 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
H&R lists a different part number. However, there isn't a huge difference, but the spring rate and progression is engineered for the S. vs the Cooper. Expect the car to sit a bit higher and may be slightly less compliant ride.
I can call H&R for you on Monday and get more specifics if you like. Let me know!
Old Oct 19, 2007 | 11:08 PM
CHDesign's Avatar
CHDesign
excellent thank you for the quick replys. Adam, if you cancheck on that for me that would be wonderful. The only thing i could thinkof is that the front may sit slightly higher than stated since there isnt as much weight in the front of the cooper vs the s. If anything maybe a sslightly stiffer spring rate.
Old Oct 20, 2007 | 07:45 AM
mini_macky's Avatar
mini_macky
when i sold my R50, i took out the springs and tried them on my R53
turns out they don't actually fit the shock base :(
Old Oct 20, 2007 | 07:59 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
r50 and r53 use the same size shocks
Old Oct 20, 2007 | 08:17 AM
Wake|MCS's Avatar
Wake|MCS
Woops guess not lol. Sorry for the wrong info.
Old Oct 20, 2007 | 01:59 PM
CHDesign's Avatar
CHDesign
Was the shock base smaller or larger on the R53 than the R50. Maybe the R53 shocks will work on teh R50
Old Oct 23, 2007 | 04:13 AM
Beecher's Avatar
Beecher
There is something diferent about them. Check out helix, thye has some form of adapter thingie for the r56. If you put r56 trailing arms on, you need these as well, but im not sure exactly what it is off the top of my head.
Beecher
Old Oct 29, 2007 | 09:54 AM
CHDesign's Avatar
CHDesign
Hey guys just letting you know I got the springs in and they installed without a hitch. Work great and provided the advertised drop.
Old Feb 18, 2009 | 09:40 AM
mitch171's Avatar
mitch171
Sorry for bringing up an old thread but I came accross this before I posted. What is the say on this. I have a r50 and of course it is much more common to find used r53 springs. Can I put them on my r50? H&R and others?
Old Feb 18, 2009 | 10:25 AM
ADAMSALTAMINI
You can use them, but the car might sit a little bit higher depending on the mfr.
Our ALTA Springs fit both the R50, and R53 but the R50 is about .2 higher in the front.
Let me know if I can ever help!
Old Feb 18, 2009 | 10:49 AM
mitch171's Avatar
mitch171
I think I know the answer but I'll ask it anyway. Will H & R springs off of a '07 s fit a '05 non s?
Old Feb 18, 2009 | 10:52 AM
ADAMSALTAMINI
NO! not a good idea! I will send you a PM!
mikeyb74
Mar 21, 2017 12:30 PM
WayMotorWorks
Aug 19, 2015 08:04 PM
Aug 19, 2015 12:51 PM
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
