Help Need help, 04 Cooper S Howling noise
Old Oct 17, 2007 | 05:13 PM
amg56aaf's Avatar
amg56aaf
I have a 2004 Mini Cooper S, I had a little run in with a curve while sliding when turning into a mall. Know I have a loud howling noise from the front of the car. I balanced the tires and checked the rims to be shore they are not bent found no problems so I rotated the tires front to rear, noise still there.
The howling gets faster and louder at 30 mph and up, the alignment is a little off could that cause the noise?
Old Oct 17, 2007 | 05:26 PM
tech guy's Avatar
tech guy
wheel bearing
Old Oct 17, 2007 | 06:00 PM
amg56aaf's Avatar
amg56aaf
Any way to test?
Is there any way to test it? Were is the best place to buy them?
Old Oct 17, 2007 | 06:29 PM
tech guy's Avatar
tech guy
are you under warranty? if not you'll need a stethoscope(try an auto parts store if you dont have one). have someone help you with this. raise the front of the car and have a friend drive the car at 10-20 mph(or faster if you need to). take the stethoscope and put the tip on the back of the steering knuckle next to the axle. probe around the hub and listen for a scraping sound. when wheel bearings go bad they are most noticeable when you are driving at high speeds and it gets louder the faster you go.
keep me updated with any progress or questions
Old Oct 17, 2007 | 06:31 PM
tech guy's Avatar
tech guy
your best bet is to go to the dealer. i haven't done front bearings on minis but on fwd cars the bearings have to be pressed in. its not an easy job you can do on a weekend in your garage.
Old Oct 17, 2007 | 07:07 PM
amg56aaf's Avatar
amg56aaf
Fix for bearings
Thanks I am under warranty I am at 38799 miles so I am still under warranty for a few more miles . Thanks for your help I did not know if it was the bearings or the transmition. I did not even think about the bears till you said something. They come as one unit, I work for a shop and we have account with a company called KW Parts and they sell them for $110 per side and napa has them for $125 per side. It looks to be a very simple install remove the brakes and rotor, then remove the axle nut and the four bolts that hold the hub on remove and replace in revers order. about 2 hours for both sides.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
maestro39
Oct 27, 2015 02:38 PM
PrimePower
Aug 16, 2015 06:29 PM
Fizzyx
Aug 14, 2015 08:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
