Navigation & Audio Need Parrot Bluetooth help
Old Oct 16, 2007 | 01:42 PM
blay's Avatar
blay
I’ve integrated a Parrot Bluetooth interface into my 2003 MCS with HK system. It's working, but not correctly.
It works as long as I don’t connect to the phone logic input (pin 11) on the HU. If I connect it the HU shows “phone” during a call but also mutes the audio. Pulling the mute connection on the HU (pin 10) high or low makes no difference.
From what I can tell there is a wiring difference for HK systems prior to 9/03. The factory wiring diagram indicates a “mute” connection to the HK amp and a connector labeled X1293 that’s supposed to be under the center console. I can’t find that connector anywhere.
Does anyone know where I can find that connection?
Thanks,
Brian
Old Oct 17, 2007 | 12:51 AM
daflake's Avatar
daflake
Might try sending an e-mail to Mikey at www.newministuff.com and see if he would be willing to help. Generally when he sells the kit it is all prewired with a harness so it is plug and play. Sounds like you bought elsewhere but he might be willing to help anyway.
Old Oct 17, 2007 | 01:14 AM
mikeythemini's Avatar
mikeythemini
Don't connect the mute pin, it tells the hk amp to mute so you will get no sound from your phone.
Old Oct 17, 2007 | 01:17 AM
mikeythemini
There is no need for it awyway as the parrot kit cuts all the speakers
navybsn
Oct 5, 2018 04:42 PM
gar56
Nov 15, 2016 06:41 AM
Chimera
Sep 30, 2015 02:53 PM
krohm
Sep 28, 2015 12:16 PM
