Alignment Issue
Old Oct 4, 2007 | 06:14 PM
RDut's Avatar
RDut
Alignment Issue
Hi All
Went to have my 04 Mini S aligned and the shop said that it needs to go to a body shop to have the front end looked at. They said that was the only way to fix the Camber. Here are the numbers
Left front camber 0.69 (spec -0.92) Right front camber -1.01 (spec -0.92)
They said the main problem is with the Cross Camber 1.70 (spec -0.50)
Can someone please tell me what to look for in the front end that might cause this issue?
Here is all the numbers
LF RF
0.69 Camber -1.01
4.07 Caster 3.59
0.14 Toe 0.13
Front
Cross Camber 1.70
Cross Caster 0.48
Total Toe 0.27
LR RR
-1.31 Camber -1.53
-0.09 Toe 0.15
Rear
Cross Camber 0.22
Total Toe 0.05
Thrust Angle -0.12
Any help would be greatly appreciated
Cheers
Rob
Old Oct 5, 2007 | 03:01 PM
HotRodPilot's Avatar
HotRodPilot
Where are you from?
I've been having serious alignment issues with my car and will be taking it to an independent shop in the next week or so. The dealership was unable to fix the alignment in the three times I brought it in to have it fixed
Old Oct 6, 2007 | 07:47 AM
RDut's Avatar
RDut
I am near Dayton OH and work at Wright Patterson AFB
Old Oct 8, 2007 | 09:59 AM
msjulie33's Avatar
msjulie33
I wonder if this is your issue ... https://www.northamericanmotoring.co...ad.php?t=78629
Old Oct 9, 2007 | 09:05 PM
RDut's Avatar
RDut
I do have a little mushrooming on the right side but I don't think it is enough to have the numbers off that much. The left side is the one that is off the most. I also checked for cracks and didn't see any. Do you have to remove the strut to see the cracks?
Cheers
Rob
rikaro
Aug 7, 2021 02:33 PM
maestro39
Oct 27, 2015 02:38 PM
Drumsound
Sep 4, 2015 04:53 AM
L3Mix
Aug 26, 2015 07:00 PM
ASRman
Aug 13, 2015 09:33 AM
