werid front end noise/my cause
Old Oct 2, 2007 | 04:49 PM
Beecher's Avatar
Beecher
hi all, just got my mini back on the raod today after 7 weeks of being off it. Had a really werid noise comming from the front end, almost sounded like an air leak, really anoying, and varied with engine speed. After much looking and listening, i discovered it was comming from the vavle area. Totaly by accident, i discovered it was the coil that was shaking. The bolts were not loose, i could barely break them loose (blue loctite by the look of it), but the coil would move around with very little effort. after i took the bolts off, and put washers under them and retightened, the noise went away. So, if you have a weird front end noise, check your coil.
hope this helps some one
Beecher
woodstudio
Mar 15, 2020 08:28 AM
ebowling
90
Aug 4, 2019 09:15 AM
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
damncajun
Aug 17, 2015 08:25 PM
