Steering Noise when car is off
Old Sep 27, 2007 | 10:27 PM
blkbeltmjf's Avatar
blkbeltmjf
I am sure you are all familiar with the steering noise that MC make, but i noticed that my car was still making this noise even when the car is off. What is going on? If anyone has any idea of what this is, and secondly how much it will be to fix let me know. I was thinking about trading in for a new one soon, this maybe the tipping point. Let me know! Thanks
Old Sep 28, 2007 | 05:28 AM
Speedwing's Avatar
Speedwing
Are you sure it was not the fan running? The fan does run after the car is turned off if it is really hot. The electric power steering pump should definitly turn OFF when the ignition is turned off. The ONLY thing that should run after the ignition is turned off is the engine cooling fan ..... and walk-away lighting.
Old Sep 28, 2007 | 11:30 AM
blkbeltmjf's Avatar
blkbeltmjf
It is certainly not the fan....whatever was running ran my battery dead.
Old Sep 28, 2007 | 12:06 PM
Speedwing's Avatar
Speedwing
Sounds like the power steering pump / relay is bad. Sometimes a failing battery will cause relay problems. I would first hook up another battery on booster cables to the car while running and then turn it off to see if the pump turns off normally. If it does ..... then check out your battery. If it does not, then the problem is with the pump electric circuit.
SEARCH will bring up a host of topics on the power steering pump issues.
Good luck!
Old Sep 28, 2007 | 12:19 PM
Electron_Mike's Avatar
Electron_Mike
If it is the steering pump relay, I'd get that checked out ASAP. Faulty steering pumps have been known to cause engine bay fires! Check out https://www.northamericanmotoring.co...ad.php?t=73527 Hopefully it's just a weak battery causing problems, but better to be safe than sorry! Best of luck in getting your problem solved.
Getrieben
Sep 12, 2024 07:03 AM
eliseo1981
Jan 28, 2021 02:45 PM
maestro39
Oct 27, 2015 02:38 PM
nismo4life
Aug 5, 2015 08:31 AM
