Service Engine Soon - p0326
Old Sep 17, 2007 | 02:33 PM
peekinde's Avatar
peekinde
Went to autozone, and...
The code indicates the following probable causes:
1. Knock sensor defective
2. Check connector and wiring to sensor
3. Engine mechanical condition - knock or rattle in engine
4. Low fuel pressure
After the SES light came up 2 nights ago, I've been hearing this rumble from my engine compartment similar to the rumble from a diesel engine.
joey1320 said it might be the knock sensor. Anyone had any similar problems? Please write your outcomes/cost.
Old Sep 17, 2007 | 02:38 PM
joey1320's Avatar
joey1320
well the noise is not coming from the knock sensor, the code is.
can you post a vid of the engine runing/rattling?
and like i had posted in the other thread, is there detonation?
do you have a "S", is your supercharger making the noise?
can you check your spark plugs for signs of detonation?
how do you know you have low fuel pressure? and if you checked with the pressure gauge, what was the pressure?
Old Sep 26, 2007 | 08:46 AM
zeus7625's Avatar
zeus7625
From: So far south in AL, one more step and I'm swimming (in oil)
SES light
Sometimes it's the simple things..........
The SES light on my wife's 02 MC went off and I quickly took it to my MINI mechanic.
When he checked the code the first thing he did was check the fuel cap. Apparently the last time the wife topped off she didn't tighten the fuel cap all the way and it threw the light.
The mechanic even pointed to the warning written right on the fuel cap. He explained that one of the faults identified on the code was Low Fuel Pressure which can be caused by a loose fuel cap. He reset the light and told me to come back if the light went off again.
Although somewhat embarressed, I was relieved that he sent me away without a bill.
Motor on!
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
David.R53
Sep 1, 2015 06:49 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:22 AM
