R56 Anyone know of good additional running (driving) lights
Old Sep 17, 2007 | 10:40 AM
kevshootz's Avatar
kevshootz
Anyone know of good additional running (driving) lights? I want to add four to the upper grill, and I know Paolo Uber makes a bar, but that mounts on the lower grill.
In my state, we have to have a front license plate. I can add two more (4 total) OEM lights to the grill, but they are small.
I am really liking the photo of the red Mini I am attaching.
Help!
Oh, and the Blue Mini is mine :-)
Old Sep 17, 2007 | 11:26 AM
mufflethis's Avatar
mufflethis
How about using the tow hook bracket for the license plate then you can add the lights to the bottom.
Old Sep 17, 2007 | 11:30 AM
jonnieoh's Avatar
jonnieoh
You can do as I did, use the ALTA kit, but with only the outer two lamps. It even saved me some money when I bought the kit, since ALTA didn't have to charge me for two pairs of lamps.
Old Sep 17, 2007 | 01:00 PM
mattbren
I mounted mine directly to the grill using small black-painted angle brackets from McMaster-Carr. They're made from 1/4" steel and are plenty strong. I put a bolt through the bracket which goes through the grill and then gets a fender washer and nut on the inside. Mine only has two on it but the grill seems strong enough to hold four. You have to use slim lights (less than 3" thick) though because the brackets don't stick out too far from the grill. Hella 500's would work fine.
Old Sep 17, 2007 | 01:29 PM
kevshootz's Avatar
kevshootz
jonnieoh, thanks for the info ... and everyone else. I am thinking two below now and 4 on the upper grill. is that excessive?
LOL
Old Sep 17, 2007 | 01:36 PM
mattbren
Georgia vehicle code says no more than two, and they have to be between 12" and 42" off the road. You might want to check the law where you live.
Old Sep 17, 2007 | 02:13 PM
kevshootz's Avatar
kevshootz
They will be hard wired to the turn on with the High Beams and only to the secondary button that tuns those on as well.
I can't imagine having 6 lights is illegal if they are not on.
Aside, I live in Chicago. So, this is more aesthetic than practical.
But thanks for the heads-up!
Wohnson89
Jun 10, 2020 04:53 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
jrezzo
Aug 9, 2015 10:32 PM
