Suspension Teflon Bushing?
Old Sep 13, 2007 | 03:54 PM
miniconcarne's Avatar
miniconcarne
Teflon Bushing?
Iautox posted a question on the 2nd gen suspention thread asking about teflon bushings. Was discussing squeaking issues with sway bar bushings (after-market, some not all). I was wondering how many people have/had squeak problems with sway bars? Also why manufacures don't use teflon bushings? Too soft? Not cost effective?
I know some sway bar manufacturers use grease zirks, but would teflon bushings be better? I also understand the teflon tape trick, but is there a reason not to use solid teflon bushings? O.k., enough babbling, I don't know much, but, I can prove it.
Old Sep 13, 2007 | 04:12 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I forgot what kind of bushings came with my Alta 22mm bar, but it used to sqeak real bad. I even used their supplied grease. Later I got some real stuff and the sqeaking stoped.
Old Sep 13, 2007 | 04:28 PM
miniconcarne
Do you have to keep re-applying the real stuff?
Old Sep 13, 2007 | 05:57 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I haven't yet, its been about 15k miles since I got the bar. I used new grease after a few weeks.
Old Sep 13, 2007 | 06:08 PM
miniconcarne
So.. no real issue? Thanks.
Old Sep 14, 2007 | 05:03 PM
Turn In Concepts's Avatar
Turn In Concepts
Bottom line is price. Teflon will be a material that's stiff enough that it would have to be machined, and there's not really a cost effective way to mold it. Urethane or rubber can both be poured or injection molded for lightyears less than teflon.
Old Sep 14, 2007 | 05:34 PM
cristo's Avatar
cristo
Alliance Member
On my previous car, I had teflon-impregnated polyurethane front control arm
bushings ('82 VW Rabbit), and they never squeaked nor needed any lubrication (and as you can gather, I had that car a good long while).
Old Sep 15, 2007 | 04:39 AM
markldriskill's Avatar
markldriskill
The bushings on my Alra 19mm rr anti-sway squeaked awfully a few miles after install. I had heard of teflon tape fix, too. But I took it back to the guy who did the install and griped until he got some "special grease" which seems to have fixed the problem for good -- at least for many K miles so far. Unfortunately, I don't know what the name of the stuff is.
Old Sep 15, 2007 | 08:36 AM
miniconcarne
Thats what I figured. If it was cost effective it would be done. It also appears that the squeak issue is easy to remedy. Thanks all who posted replys.
Old Sep 15, 2007 | 12:35 PM
ninjlao's Avatar
ninjlao
Ninja Mini
what I do with some of my cars is put on some teflon tape inside my polyurethane bushing.
YaTuSabe
Aug 23, 2018 11:41 AM
bahman
Feb 14, 2016 10:29 AM
pahg
Oct 5, 2015 11:50 AM
rt808
Sep 29, 2015 03:15 PM
Suspension Products
Sep 10, 2015 11:46 AM
