Suspension Strut & Camber Plate Torque Specs
Old Sep 12, 2007 | 09:23 PM
jmature's Avatar
jmature
I am looking for the torque specs on a 04 MCS for the pinch bolt for the lower half of the front struts? and the nut which holds the chamber plate to the strut shaft? and the swaybar to strut nut? Thanks for any help.
Old Sep 13, 2007 | 12:53 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Torque specs from Bentley service manual for 2002-2004 MINI Cooper (S)
1- Front Strut to steering knuckle pinch bolt 81 Nm (60 ft-lb)
M12 x 1.5 x 60 mm
2- Upper strut mount to strut shaft (Center strut retaining nut)
64 Nm (47 ft-lb)
Models from 3/2002 : M14 x 1.5
3- Stabilizer bar link to lower spring seat or to strut tube bracket
M10 x 1.5 56 Nm (41 ft-lb)
And for the strut top mounting nut (3 for each side to hold camber plate to strut tower. M8 x 1.25 34 Nm (25 ft-lb)
dropnstylez
Oct 29, 2015 08:57 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Sep 3, 2015 02:06 PM
Suspension Products
Sep 3, 2015 09:41 AM
cw40342
Sep 2, 2015 06:01 AM
