Suspension 05' Stock Rear Control Arms
How many degrees will a Stock 05' w/ Sport Suspension be able to dial out in negative camber? I am looking for -1 degree
Might be my next purchase Helix rear control arms and front camber plates
(Well did buy 15" Studded Pirelli Snow Carve on Steel wheels today from TireRack)
Normally your rear camber should be about -1.0 to -2.0 and be within Stock settings. You can change whatever it is by about 0.5 degrees total. So if it is at -1.4 on the left and -1.6 on the right and your adjusters are about in the middle of their range then you can pick about -1.3 to -1.7 degrees with right and left matching.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
Minibeagle
Aug 13, 2015 10:00 AM
