Suspension strut mounts
Old Sep 5, 2007 | 07:31 PM
ryansoxfan's Avatar
ryansoxfan
strut mounts
my strut mounts are cracked and need to be replaced. is there a better aftermarket version than buying them from mini? also, should i install camber plates and a brace when i replace these mounts? i don't want this problem to happen again and i wouldn't mind beefing up my suspension.
Old Sep 10, 2007 | 03:33 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I recomend Ireland Engineering adjustable camber plates. There is no rubber to tear, you can even-out/set your camber, and they are anti-mushrooming.
A strut brace...there is much debate whether this does anything worthwhile, or if its for show. The cars are so rigid already. Also the braces can block access to the oil filter, airbox, coolant tank, powersteering tank, they can raise the hood up and they add weight.
where in nebraska do you live? im in lincoln
Old Sep 10, 2007 | 05:27 PM
ryansoxfan's Avatar
ryansoxfan
i actually ordered a set from ireland last thurs. did you install yours yourself? the suspension shop wants $300 to do it and i don't have that kind of cash. i also live in lincoln. any chance you could lend a hand installing these? it would be greatly appreciated. thanks for any help/info.
Old Sep 10, 2007 | 10:25 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
One of my shock towers was mushroomed (one of the reasons i bought these). I had the work done at Graham Tire. I didn't have the proper tools to disassemble the front end. You may need a spring compressor and some airtools. And they have repaired mushrooming on many cars before.
If you have that stuff I could help anyday this week or weekend. Ive done everything else on my car myself except the brakes (done at Midas for safety reasons) and clutch (lack of engine hoist), so i know my way around these cars.
patsum
26
May 29, 2021 06:29 PM
Supertractor3
Apr 7, 2017 11:16 AM
ej
Nov 17, 2015 09:21 PM
M7Speed
Sep 4, 2015 10:47 AM
Suspension Products
Sep 3, 2015 09:41 AM
