Tire Pressure/ABS/ASC Alarm
Old Sep 5, 2007 | 06:10 AM
robertsmau's Avatar
robertsmau
Here's my issue, when I hit a large bump in the road the tire pressure warning light comes on followed by the ABS and ASC lights. If I restart the car the tire pressure light clears and if I restart the car a second time the ABS and ASC lights clear and I'm on my way again. Tire pressures are fine at 34psi cold on some very strange Hanking tires (I just bought the car). I haven't captured any codes yet but I thought someone would know a fix or diagnose the problem for me.
Old Sep 5, 2007 | 06:39 AM
Coopaw's Avatar
Coopaw
Sounds like a loose ABS sensor but I'm no expert. Could be just a connector that's not tight. Should be a quick fix at the dealer.
Old Sep 5, 2007 | 06:55 AM
robertsmau's Avatar
robertsmau
I don't do dealers, its like visiting satan. What should I look for when checking connectors and sensors?
Old Sep 5, 2007 | 07:00 AM
jakay11's Avatar
jakay11
Typically, I'd agree, but is your car still under warranty?
If so, its their buck, not yours...
(the new-car warranty stays with the car, regardless of how many times its sold, as long as its within the time (yrs) and miles...
Old Sep 5, 2007 | 07:24 AM
Mini Works's Avatar
Mini Works
They are correct,
You have a bad wheel sensor, your dealer should take care of that in an hour.
Old Sep 5, 2007 | 08:19 AM
robertsmau's Avatar
robertsmau
55,000 miles so I'm assuming its out of warranty. What's the best way to determine if a wheel sensor is bad and which one?
Old Sep 6, 2007 | 06:20 AM
robertsmau's Avatar
robertsmau
I was thinking aboutthis last night. Why would a wheel sensor set off the tire pressure monitor? Is there something else it could be? Could it be a failed tire pressure sensor? Is there a way to check them?
Old Sep 6, 2007 | 10:01 AM
MINIAC's Avatar
MINIAC
The TPMS uses the ABS sensors to monitor the rolling radius of all four tires and warns the driver if there is a drop in tire pressure.
Old Sep 6, 2007 | 01:03 PM
robertsmau's Avatar
robertsmau
Fascinating, I guess I better get those wheels off and start cleaning and inspecting some speed sensors. Thanks everyone for the advice, I'll report back what I find.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Ntety
Sep 2, 2015 08:39 PM
