Cruise Control Issue
Old Sep 1, 2007 | 09:17 PM
Alerious's Avatar
Alerious
I'm not sure where to begin with this one. I had my MCS recently serviced to have the clutch/flywheel changed and now my cruise control is no longer working. I know I can enable it since the light turns green on the tachometer, but it doesn't appear to want to set the speed when I press the + symbol... the speed just keeps dropping until I press the gas, no matter how long I hold the button down. Has anyone experienced anything like this before and what did you do to resolve it? Thanks!
GotMINI
Old Sep 2, 2007 | 08:32 AM
Phantom's Avatar
Phantom
sounds like to me they didnt hook something up, I would take it back to them and let them know whats up. In the mean time you could just take a gander under the hood to see if you notice any loose connections, also might want to check fues though I dought that is the issue.
Old Nov 30, 2007 | 02:27 PM
nixjosh2's Avatar
nixjosh2
Did you ever get this fixed, my 05 has recently been having this issue as well and would like to see an outcome, It was in service recently for a thermostat leak
Old Nov 30, 2007 | 02:48 PM
Capt_bj's Avatar
Capt_bj
Check vac lines
In my experience .... this type of problem has always come down to a bad vacuum line....check for a disconnected or loose or cracked hose....
or if under warranty try the dealer
Old Dec 18, 2007 | 01:09 PM
nixjosh2's Avatar
nixjosh2
Global Imports figured out the problem. It turned out to be a faulty brake light sensor behind the brake pedal. Thus the cruise control could not figure out if the brakes were being applied or not and so would not engage.
The Mini cruise control is electronic and does not deal with vacuum lines at all, according to Global Imports.
Oh well, should have the part in tomorrow and my long drives will be more comfortable
Old Dec 18, 2007 | 01:30 PM
MINIdave's Avatar
MINIdave
My dealer changed the same part on my '03 when the cruise quit working, a month later they had to change the steering angle sensor when it quit again, just FYI......
Old May 23, 2012 | 06:59 PM
gokaht's Avatar
gokaht
I'm having the same issue - cruise won't engage, but the light comes on/off as it should with the "power" button. Should I throw a brake switch in there? My brake lights come on - wouldn't the bad switch avoid that?
W0TM8
Dec 19, 2019 07:50 AM
minicooperlover22
Northwestern Indiana MINIacs
Aug 14, 2015 03:13 PM
PatrikKN
Aug 5, 2015 09:10 PM
Llanrhaeadr_Cymru
Country Roads MINIs
Aug 5, 2015 02:58 PM
