Suspension Rear Sway bar
Rear Sway bar
I have just got the TSW springs, now I am looking for a rear sway bar.
However, I do not know which one should I get (18MM,19MM, 21MM or 22MM)???. Keep in mind that I do around 3-4 track days and 4-5 auto-x events a year...and I the MCS is not my daily driver...it has just turned into the weekend toy.
I would consider an adjustable bar; your range of driving venue is as big as it gets. What works on a track is almost not suitable for autoXing and if you install camber plates, you will more than likely find that a big bar is too much for anything but an autoX event.
The Webb Bar works well, but it costs around $500.00. I have one and I like almost everyhting about it.
I would have suggested a 19mm if you didn't inlcude autoXing. But that size is a perfect size in my opinion for things non-adjustable. You get more of what you want without fear of the backend passing the front end...not always fun
I use the 22mm hollowed Ireland, noisy at low speed due to the bottom rod ends - cheap, which I changed already - but works great with infinity adjustability.
A MCS is never to loose on the rear to oversteer, if it tends to, just give more gas and it will pull you off the oversteer, Ask me how I know... :-)
