Navigation & Audio MP3 player works fine with aux jack, SIRIUS not so much
Old Aug 27, 2007 | 02:33 PM
phillyunderworld's Avatar
phillyunderworld
i just recently installed the aftermarket aux jack . when i plug my mp3 player in there it works perfect. however, when i hook up the line to the line out of the sirius radio dock the aux display disappears and it stops working all together. when i hook the mp3 player up again all i have to do is hit the mode button a couple of times and it starts working instantly. i don't get it? is it because the sirius dock has an fm transmitter built into it?
Old Aug 27, 2007 | 03:20 PM
rkw's Avatar
rkw
Is your MP3 powered by its battery but the Sirius is powered by your car (e.g. cigarette lighter)? If so, the power connection is probably creating ground loop noise that is confusing the stereo. It can be corrected by using a ground loop isolator like this. Do a forum search on "ground loop isolator" for more information.
Old Aug 28, 2007 | 02:37 PM
phillyunderworld
thanks for the response. i hope that works. why the hell would they even bother putting the line out of the sirius dock if you only have to buy this groung loop isolator. very stupid
Old Aug 28, 2007 | 04:08 PM
phillyunderworld
just got the ground loop isolator from a local radio shack.everything works perfect now. thanks rkw. the only thing that sucks is i had to buy a dual phono to 1/8 inch y adapter to make it work. thanks again
Old Aug 29, 2007 | 08:34 AM
btallack's Avatar
btallack
I actually spliced a ground loop isolator between the head unit and the aux jack myself to keep it clean and to avoid this issue.
surfblue
Oct 24, 2018 01:20 AM
stellaherself
Aug 14, 2015 05:28 AM
minipopkart
Aug 13, 2015 05:22 AM
DWooderson
Aug 10, 2015 09:12 AM
