Suspension The next step...
Old Aug 26, 2007 | 11:47 PM
rjtrout2000's Avatar
rjtrout2000
The next step...
Well, I have added stainless steel brakelines and a rear sway bar to the mix on my car. Now I am looking at one more mod that could really make it an excellent handler on my local mountain roads.
Currently, I run the holies and some 195/50/15 performance tires. The tires and wheels seem to be a good match and I really don't feel like lowering the car THAT much. However, I am torn between either upgrading to:
Rota Slipstream wheels with some Advan AO48 tires
the M7 USS
So, I guess the question is whether or not I should go with the USS or an upgraded wheel and tire setup next. Any thoughts either way?
Old Aug 27, 2007 | 12:10 AM
JustJAY's Avatar
JustJAY
I would do suspension, though I know you said you don't want to lower your MINI, it will corner better. Perhaps you could do camber plates as well.
Old Aug 27, 2007 | 12:47 AM
rjtrout2000
IIf I do go the lowering path, I am doing the TSW springs for sure. However, I can't help but think that there is something else IO can do to improve the handling without going to yet another Driving Class or lowering the car. Maybe the USS would be better?
Old Aug 27, 2007 | 12:49 AM
rjtrout2000
Also, would lowering be effective with the OEM size tires (175/65/15) that come with a stock cooper?
Old Aug 27, 2007 | 06:48 AM
SayGoodbye's Avatar
SayGoodbye
Old Aug 27, 2007 | 07:44 AM
ScottinBend's Avatar
ScottinBend
In regards to the USS. The benefits are questionable for other than the convertables (and even those are under debate). Going with new tires will give you the biggest bang for the buck at this time.
Old Aug 27, 2007 | 08:27 AM
MINIMM's Avatar
MINIMM
Camber plates will help your turn in a lot and also help with front tire wear.
Old Aug 29, 2007 | 03:59 AM
etalj's Avatar
etalj
x2.
Get adjustable front camber/caster plates and get a decent alignment. You won't regret it.
inh
Suspension
Apr 20, 2014 11:45 PM
cadfael_tex
Detailing 101
42
Jul 18, 2007 07:09 PM
Prima Car Care
Detailing 101
Jun 13, 2007 08:23 PM
theroyalwe
MINI Camera and Video
Dec 27, 2005 11:00 AM
