Suspension Tightning the rear shaft nut.
I installed a set of coils.. which may come out soon.. however, i have a quick question about rear shaft nut.
its a nut with nylon top on it and when i tried to tighten it down, it wouldn't go all the way down even with some impact actions. stuck at right at fully threaded poistion. i can't even use allen wrench cuz of koni adjustment thinge.. and i hear clunks and clanks right now, which i hihgly suspect that the not 100% threaded nuts are causing the issue..
any tips on how to ? frustrating..
thanks!
thanks!
install washer shims?
SPRP85,
Can feel your pain. A possible solution: (if you can back the Nyloc nuts off) install a couple of 10mm flat washers on the strut shaft, under the Nyloc nut. Reinstall a new 10mm Nyloc nut and see if you and cinch the nut down tight against the washers. Have done exactly this with my rear struts when I fabricated some mono-ball bushings and needed to make a minor adjustment to the bushing depth. Works perfectly in my situation.
My best,
John Petrich in Seattle
My best,
SPRP85,
My best,
My best,
again, thanks!
aldito2
Nov 25, 2015 09:33 PM
