how to test voltage regulator?
Old Aug 15, 2007 | 08:14 AM
pimpedout97x's Avatar
pimpedout97x
heres my other thread: https://www.northamericanmotoring.co...d.php?t=110611
turns out my alt and batt are both good. now, this guy had the same problem occur, he said it ended up being his voltage regulator, but he already ordered a new alt. http://www.metroplexmini.org/forum/s...d=1#post328915
how can i test my voltage regulator to see if thats the problem? sear's said the alt tested good.
Old Aug 15, 2007 | 09:35 AM
hemiheaded18's Avatar
hemiheaded18
Its more than likely that the VR is part of the alternator. I would assume it is and if it is, it can't be tested seperately. Did they test it on the car or off? With it off is the only way to determine if that unit is bad. Going to a Sears Auto Center is like going to Pep Boys anymore, BTW. A joke. You could have an open lead, a bad ground, a bunch of things.
Old Aug 15, 2007 | 09:46 AM
pimpedout97x
the tested with it on and off i think, both tested good.
Old Aug 15, 2007 | 09:47 AM
pimpedout97x
and the VR is inside the alt.
Old Aug 16, 2007 | 07:46 AM
hemiheaded18
It could be an open lead, a bad ground, internal wiring problems ie-too much resistance. A number of things. This is where it gets hard as you pretty much start chasing wires with a voltmeter.
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
jennster
Sep 28, 2015 06:19 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
silence2-38554
Sep 28, 2015 12:19 PM
Sep 25, 2015 11:46 AM
