Suspension strut re-inforcement plate questions
Old Aug 11, 2007 | 09:48 PM
rjtrout2000's Avatar
rjtrout2000
Now, I just bought my plates today and put them on when I got home. I bought these to simply prevent a future mushrooming incident. The car always had driven completely fine.
However, after I put the plates on, the car seems to want to pull more towards the right than it did before. Does anyone have an answer or at least an educated guess as to why this may be happening? Please give me some feedback ASAP!!!
Old Aug 12, 2007 | 06:35 AM
PlayPlay's Avatar
PlayPlay
How did you put them on? M7 plates?
Old Aug 12, 2007 | 08:40 AM
chadtoolio's Avatar
chadtoolio
M7 style plates(above the strut tower)? Not possible with the plates alone...Maybe did you just notice a problem or is your car just drifting to the right due to roads being crowned?
Old Aug 12, 2007 | 08:53 AM
Crashton's Avatar
Crashton
First check your air pressure. A couple of pounds difference left to right will cause a car to pull. I doubt very much that installing those plates caused your pull.
Old Aug 12, 2007 | 04:36 PM
rjtrout2000
Well, I checked the tire pressure and that was fine. However, it may have to do with the roads here in colorado. Regardless, I just also put on the Alta sway bar and will be getting the car re-aligned shortly!!
Old Aug 12, 2007 | 05:10 PM
Crashton's Avatar
Crashton
Well that's the easiest thing to check. If that's a rear swaybar it shouldn't effect your alignment. If it's been a while since the alignment has been checked, that may be a good idea. Yep roads really can make a car pull one way or the other.
Old Aug 13, 2007 | 08:57 AM
minjae's Avatar
minjae
sorry to somewat take over your thread.
but i have a question about the actual installation.
do you NEED a torque wrench? i dont have one to measure to 25 ft-lb.
( i still dont really get it tho.. )
i do have a socket wrench. is that enough to install?
(didnt feel like starting a new thread. thanks in advance!!)
Old Aug 13, 2007 | 09:14 AM
PlayPlay's Avatar
PlayPlay
When I called M7 about this they just said to hand torque it....but since then there have been other things to use a torque wrench on so I just bought one...prol worth the $30 just to have one.
Old Aug 13, 2007 | 09:21 AM
minjae's Avatar
minjae
cool. thanks for the quick reply. i know there wont be a noticeable difference in driving but for some reason i cant wait to put it on.
guess it's cause it's a new mod
Old Aug 13, 2007 | 09:46 AM
BlimeyCabrio's Avatar
BlimeyCabrio
First thing I put on as soon as Blimey was in my garage...
Old Aug 13, 2007 | 10:28 AM
COR BLMY's Avatar
COR BLMY
installing a sway bar (rear) CAN mess up your thrust alignment !
If you drop or even loosten the rear sub frame it does not just fit right back in the same spot.
this can cause the vehicle to "crab".
When doing sway bars I use a paint marker at the bolt flanges for L & R and F & R alignment, I scratch a fine line in that paint ... then ues the scratch for use in reattaching the rear sub frame.
Old Aug 19, 2007 | 03:15 PM
jefeant's Avatar
jefeant
I respectfully disagree with you guys.
The car should NOT loose the alignment by installing the strut plates, dropping the rear subframe, lower springs (no more than 1") or installing a thicker swaybar. All those components go in and out in ONE WAY ONLY. If you feel something different after changing any of those PROPERLY look for something else wrong.
Old Aug 19, 2007 | 05:06 PM
Crashton's Avatar
Crashton
+1
Old Aug 19, 2007 | 06:51 PM
COR BLMY's Avatar
COR BLMY
Strut plates and springs your OK ...
But you are WRONG about the rear sub frame
The front wheel alignment will be fine.
If you read front ONLY
However the THRUST or back to front alignment can change
next time you remove or even loosten the rear subframe .... mark it,
Do you sway or what ever and just put the bolts back without looking at alignment (of rear subframe) it WILL be off.
I have done well over 20 and have seen a lot of movement
Old Aug 19, 2007 | 06:56 PM
Crashton's Avatar
Crashton
I've only done one. I looked at where it was & made sure it was in the same place before tightening up. I didn't mark, but the dirt marks showed the place it was. Glad I checked before tightening.
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
