MOTEGI TRACK TRAKLITE
Old Aug 1, 2007 | 10:23 PM
mistro's Avatar
mistro
I'm considering these wheels with Goodyear Eagle GSD3 P21540R17. The wheels are: Offset: 42mm Bolt Pattern: 4-100
Rec. Tire Size:205/45-17
**Lightweight: 11.0lbs.**
Any issue with fittament on a 05 MCSC? TIA Michael
Old Aug 1, 2007 | 10:46 PM
nypepper's Avatar
nypepper
they will fit just fine
if your are looking at the wheels i think you are, they are in mine condition and the seller is a great guy
Old Aug 2, 2007 | 01:04 PM
gp1007's Avatar
gp1007
11 lbs @ 17 inch diamter? you sure?
Old Aug 2, 2007 | 01:10 PM
F15EWeapon's Avatar
F15EWeapon
Awesome wheels... well made and very light. Don't hesitate. 42mm offset is great for our cars.
Old Aug 2, 2007 | 05:24 PM
84im's Avatar
84im
Try 14 pounds.
http://www.wheelsfortuners.com/detail.aspx?ID=133
Old Aug 3, 2007 | 09:34 AM
Mgibrace's Avatar
Mgibrace
Still a great weight and the tire and size will work fine. Go to tirerack and click on specs, then look at recommended wheel widths. You'll be ok.
Old Aug 22, 2007 | 10:05 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Are these the Tracklite in 17x8 size??? If so I had the same question, with 215/40-17 Falken RRT-615s
Old Aug 22, 2007 | 11:00 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Motegi Track Traklite
has two weights and only comes in 17x7 at tirerack.com
Both are $280 each
Flat Black painted 14 lbs
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Anthracite with Machined Lip 11 lbs (closeout!)
http://www.tirerack.com/wheels/Wheel...er=23817749AML
Old Aug 22, 2007 | 11:20 PM
mini-ff's Avatar
mini-ff
I have these wheels with rt 615. 215-45-17 with no problems.
Old Aug 22, 2007 | 11:27 PM
howsoonisnow1985
Thats why I don't like TireRack site you are forced to look at only OEM sizes!
Wheel:
Motegi Traklite 2.0 Part No:
2318-7849
Size:
17x8
Offset:
42
Backside:
6 1/8
Bolt Pattern:
4x100
Weight:
14lbs.
http://www.motegiracing.com/wheels/d...&name=TRAKLITE 2.0 Glossy Black&pic=2318&style=2318&desc=1-piece forged alloy, painted center, machined lip
Old Aug 22, 2007 | 11:28 PM
howsoonisnow1985
Do you have the 17x8??
Old Aug 22, 2007 | 11:32 PM
mini-ff's Avatar
mini-ff
No, they are 17x7, et42. flat black
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
gnhovis
Sep 28, 2015 10:56 AM
