Stock OE offset question...
Old Jul 20, 2007 | 10:24 PM
WannaMini_'s Avatar
WannaMini_
...I am running G-Stock autocross. I am going to purchase some used SSR Comps 16 x 6.5 (OE size, which it has to be). BUT! You can put ANY tire on them that you want. I will be putting 225/50R16s Kumho V710s. So my question is - what's the "legal" offset on that setup?
Old Jul 22, 2007 | 02:45 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
G-stock requires rims that are the same overall diameter and width as stock with offset that is plus or minus 1/4" from stock offset of +48mm.
The SSR Comp R rims that were sold by tirerack.com in 16x6.5 to match the stock MINI rims are of the correct offset about +45mm.
The most common sizes to put on those rims are-
Kumho V710 215/40-16 $175 each 19 lbs 22.6" tire diameter
Hoosier A6 205/45-16 $206 each 19 lbs 22.8" tire diameter
225/50-16 ($209) is heavy at 24 lbs and taller than stock at 24.7"
Colt45Magnus
Aug 27, 2024 05:03 AM
schwac2
Jun 14, 2016 04:06 PM
actualsize37
Nov 18, 2015 08:58 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
jesterofatlas
Sep 4, 2015 11:23 PM
