R50/53 Clutch noise at launch?
Old Jul 20, 2007 | 09:52 AM
Tomcatta's Avatar
Tomcatta
Okay, help me out before I go to the SA next week so I don't let them talk me out of a possible repair issue. Any time my MCS has been sitting
for 8+ hours and then driven, the first 5-11 releases of the clutch
produces a noise. I can only describe the noise as the sound your car
makes after it has just been washed and the brakes are applied. Like a
rubber on metal sound. Maybe like a gum based eraser across glass, I
don't know. From what I can hear (with the windows down) the sound only
happens when leaving a stoplight under light acceleration. As I said
roughly the first 5-11 times. I thought it may have been a brake noise until I was able to slow to a light w/o the brakes and heard the same noise.
Old Jul 20, 2007 | 09:59 AM
Mini-Wingnut's Avatar
Mini-Wingnut
Noise
I have the exact same noise. I was also going to take my MINI in and have service look at it. I didn't hear this noise when I first got the car, only after about 4000ish miles. I have a little over 7000 on the car now. How many miles are on your car? Mine is an 06 MCS. Thanks!
Old Jul 20, 2007 | 10:04 AM
Tomcatta's Avatar
Tomcatta
My car gets driven alot! Approx 45K on a 2005. No other clutch issues than a new slave cylinder.
Old Jul 20, 2007 | 10:59 AM
Minzila's Avatar
Minzila
noise
My 02 MCS did that. The dealer replaced the dual mass flywheel under warranty. No more problem.
Minzila
Old Jul 20, 2007 | 11:02 AM
Tomcatta's Avatar
Tomcatta
Interesting! I had made the typical complaint about rattling in idle that is caused by the flywheel and they said it was fine and would probably rattle with a new one. When you took yours in, was the flywheel replaced because of the noise we mentioned, the rattle in neutral, or both?
Old Jul 20, 2007 | 11:28 AM
Minut's Avatar
Minut
Search button. Learn it, live it, love it.
https://www.northamericanmotoring.co...=clutch+squeal
Old Jul 20, 2007 | 11:54 AM
Tomcatta's Avatar
Tomcatta
Thank you! I had tried searching, but apparently not with the right criteria.
Old Nov 1, 2007 | 09:06 PM
Mini-Wingnut
Follow up...
Just a quick follow up...Long Beach MINI was able to reproduce the sound, so I got a new clutch and dual mass flywheel installed today all under warranty. Lets see if that fixes the problem.
Old Nov 5, 2007 | 08:53 AM
findude's Avatar
findude
Originally Posted by Mini-Wingnut
. . . able to reproduce the sound, so I got a new clutch and dual mass flywheel installed today all under warranty. Lets see if that fixes the problem.
See my post on this in an earlier thread at https://www.northamericanmotoring.co...95#post1707495.
Then again, mine is doing it again barely two months later, so I may have to go through the rigmarole all over. . . .
Supertractor3
Apr 7, 2017 11:16 AM
jarymo
Hawaii MINI Motoring Club
Sep 30, 2015 04:19 PM
Sc00terbum
Sep 11, 2015 07:17 AM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
