R50/53 Need your HELP... removing headlights from 2005 Cooper S
Howdy folks,Does anyone know how, or have directions on how to remove the headlights from the 2004 cooper S?
My lens covers have some kind of scum on the inside and I want to remove them so I can clean them. I looked under the bonnet but didn't see any clear way to remove these without having to mess with every screw and nut. Plus I may have to get the bonnet repainted and don't want mask lines around the headlights.
Many thanks,
Jim
redmini04
The headlight units themselves are held to the bonnet by 4 screws...well 4 nuts under the bonnet. I know because mine came loose and I had to tighten them. Once you get them off, I have no idea how to clean the lenses from the inside.
Sorry, not much help here.
yeah, you'll have to pop them in the oven to loosen up the silicon so that you can pry off the lens. and then reapply more silicone once your finished cleaning. you should go ahead and paint the housing while your at it
Thanks all. I don't know what the seal is but inside the lens's there is a slight fog. They used to be crystal clear. I've done nothing to break any seal either. Oh well, not a big deal - just tear them out and clean them.
Thanks again
Jim
Thanks again
Jim
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
