Suspension s stock shocks
Old Jul 14, 2007 | 04:51 PM
manoo's Avatar
manoo
s stock shocks
hey how long have your mcs stock springs lasted??? i am 90,000 miles on my 2003 original springs and thinking they feeling a little tired. any thoughts?
Old Jul 14, 2007 | 05:09 PM
Crashton's Avatar
Crashton
I'd guess that you springs are most likely OK, but I'm sure you need struts in front & rear. There are aftermarket alternatives or you can watch the marketplace forum here & snag a set of take-off new ones.
Old Jul 14, 2007 | 05:40 PM
manoo's Avatar
manoo
struts?
ok. thanks for that. what do you think of the oem struts. i have h sports springs, rear control arms and bar but i honestly haven't thought about struts...
i think that the handling of the oem shocks is pretty good. your opinion?
Old Jul 14, 2007 | 05:45 PM
Dr Obnxs's Avatar
Dr Obnxs
Vocabulary...
the strut is the shock on a Mini, it's defines the suspension geometry and carries the load of the front. A Shock typically is just a dampener and carries no load.
For most conversations, you can use the phrases interchangably.
But with that kind of mileage on the car, that's where you should be looking. "Tired" springs sag.... Also, make sure that your front control arm bushings arn't shot either.
Matt
Old Jul 14, 2007 | 05:50 PM
manoo's Avatar
manoo
oh
thank you for the clarification on useage of words. i didn't realize that the words shock and strut were interchangeable. i do think i need new shocks...
one bushing has been replaced and the springs are still springy...
Old Jul 14, 2007 | 06:00 PM
Crashton's Avatar
Crashton
All I have experience with are stock springs & shocks. The only modification is a 19mm H-Sort rear swaybar. For me they work great. My criteria to be happy is a good ride & enough ground clearance to get clear a dead ground hog without dragging.
Since you have lowering springs there may be a better shock out there for you. I'm sure someone will chime in with that info.
Colt45Magnus
Aug 27, 2024 05:03 AM
molala
Oct 2, 2015 01:53 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
jesterofatlas
Sep 4, 2015 11:23 PM
Suspension Products
Sep 3, 2015 09:41 AM
