2006 JCW Wheels
Old Jul 13, 2007 | 07:36 PM
2MINI2C's Avatar
2MINI2C
2006 JCW Wheels
Being a real noob, I hesitate to ask a question that has probably been covered previously. If if has, I can't find it. I want a second set of wheels on which to mount all season or winter tires. My question is.....will all MINI OEM 17" wheels work with JCW brakes without spacers? If not, which OEM 17" wheels will clear JCW calipers (stock JCW suspension) without using spacers?
I don't want to buy wheels and then have to worry about spacers, longer length lugs, etc.
Thanks for any insight you may have.
Old Jul 13, 2007 | 07:46 PM
Scavenger's Avatar
Scavenger
MINI2 has this great guide to wheels and tires, check it out: FAQ & DIY: Wheels and Tyres
Old Jul 13, 2007 | 08:39 PM
lhoboy's Avatar
lhoboy
All of the MINI OEM 17" rims will fit over the JCW brakes. No special anything (including spacers) needed.
Old Jul 13, 2007 | 11:25 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You should be fine.
All MINI wheels have holes drilled to 16mm so they will fit both older MINIs built before 7/12/06 and those built since then with 14mm bolts.
see
https://www.northamericanmotoring.co...ad.php?t=95060
Aftermarket rims don't always fit- you have to be careful. Tirerack.com asks date of build for 2006 MINIs but not all vendors ask.
Dec 23, 2015 10:36 AM
SosoMINI
Nov 22, 2015 03:17 PM
nomar116
Aug 10, 2015 11:24 PM
