R50/53 Motormount Goo?
Old Jul 3, 2007 | 05:28 PM
cpayne's Avatar
cpayne
Motormount Goo?
I have this brown hard substance just below the motor mount where it bolts in and the negative terminal of the battery attaches. Is this something that leaked from the Motormount?
Thx
cp
Old Jul 3, 2007 | 05:33 PM
Scooby03's Avatar
Scooby03
Thx
cp
Yes it is. We change them all the time.
Old Jul 3, 2007 | 05:36 PM
minimarks's Avatar
minimarks
Dang... I just got the same crap. Is there a better mount to use or just stick with stock. Also is this something warrenty should cover... PS: Bout how much are those...
Old Jul 3, 2007 | 05:44 PM
Scooby03's Avatar
Scooby03
We charge a little over $80.00 for them. Should be covered under warranty, but I have read where sometimes there not.
Old Jul 3, 2007 | 05:46 PM
cpayne's Avatar
cpayne
Thx..good ole' google got me some answers. But do you just go OEM or is there an aftermarket solution?
cheers
cp
Old Jul 3, 2007 | 05:50 PM
Scooby03's Avatar
Scooby03
cheers
cp
For right now, OEM. Were working on a fix, but not there yet. We keep several instock, as we change them a lot.
Old Jul 3, 2007 | 08:36 PM
cpayne's Avatar
cpayne
Sounds good..can I order from you on-line? If so direct URL?
Thx
cp
Old Jul 3, 2007 | 09:06 PM
70spop's Avatar
70spop
It should. I just had my motor mounts replaced again at 84,000 miles. They were covered under my extended warranty. First time they were covered by the regular warranty.
Old Jul 4, 2007 | 09:40 AM
Scooby03's Avatar
Scooby03
Thx
cp
Send me a pm with your address and I will get you a total tomorrow when I get in the shop
Old Jul 4, 2007 | 10:14 AM
Rockit Man's Avatar
Rockit Man
Warranty covered mine too.
Old Jul 4, 2007 | 04:30 PM
jabell2r's Avatar
jabell2r
Coordinator :: M2C2
Some of the guys in my local club have a small brace that mounts to the motor mount bracket and the frame. It is adjustable and keeps the stock mount from over extending on hard accelerations. This seems to have solved their problem. I was going to get more info at my next meeting and order one. If you check with your local club I'm sure someone has it.
Old Jul 5, 2007 | 05:31 AM
DixonL2's Avatar
DixonL2
Check with LordOfTheFlies for an "engine dampner". On the '05-'06 they don't make a lot of difference in vibration but do stabilize the engine under load and may help prevent motor mount failure. TSW makes one too, there may be others. A quick search under "engine dampner" should bring up a few threads. Installation is pretty easy for either one, and they don't cost much.
Your motor mount should be covered under warranty. Check with your dealer.
Old Jul 5, 2007 | 07:39 AM
cpayne's Avatar
cpayne
Thanks..I have sent LordofTheFlies an email. If this is a solution to a part that might fail again under warranty I dont mind fixing the problem
Thx!
cp
Old Jul 10, 2007 | 09:11 AM
03Indigo's Avatar
03Indigo
User Title's are Silly
I have one of these from TSW...similar to LOTF damper...but different mounting points. Has worked well for me
http://www.txwerks.com/servlet/Categ...%3ADamper+Kits
Old Jul 25, 2007 | 10:22 AM
cpayne's Avatar
cpayne
Anyone have a write-up on replacing the leaking Engine Mount?
Thx
cp
Vaderm34
Sep 27, 2015 09:25 PM
brigadoonb
Apr 6, 2008 12:38 AM
JohnTurbo
Nov 20, 2007 09:48 AM
Moneypenny
Detailing 101
Jun 23, 2005 12:56 PM
