wilwood brake bleed
Old Jun 29, 2007 | 12:50 AM
stuttgart1's Avatar
stuttgart1
wilwood brake bleed
Yesterday I tried to bleed my Wilwood Dyna Pro brake, when I bleed I loose the top two bleed nipple but the brake padel is very hard, I tried to loose all 4 nipple the padel feel is still very hard. Anyone have idea what's going on? Thanks for the help.
Old Jun 29, 2007 | 01:41 AM
mylittlemini's Avatar
mylittlemini
if you just installed them, i'd check the brake lines to make sure they aren't twisted or kinked. of not kinked or twisted i'd remove the brake line from one caliper at a time to see if any brake fluid drips out. if no fluid drips out then somehow you got a restriction in the line. if fluid is dripping out then theres something going on with the caliper itself, but it sound like your not getting anything to the caliper.
i dont know much about the wilwood setup but i can't imagin its to much different from any other system.
Old Jun 29, 2007 | 03:08 PM
toddtce's Avatar
toddtce
Bleeding is by way of the top only. As stated; fluid should flow freely at the hose.
sempaipaul
Sep 18, 2015 03:05 PM
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
