wheels
Old Jun 28, 2007 | 12:34 PM
minipooper02's Avatar
minipooper02
wheels
I am trying to order some 17 inch rims online and I need to know what size rims and bolt pattern and offset blah blah blah will fit the mini. Please someone help me out.
Thanks!
Justin
Old Jun 28, 2007 | 12:37 PM
ZAMIRZ's Avatar
ZAMIRZ
Justin, if you do a search, you will find all the pertinent information you're looking for. It has all been posted before.
Old Jun 28, 2007 | 01:14 PM
minipooper02
Cant find it.....:impatient
Old Jun 28, 2007 | 01:57 PM
JCW Driver's Avatar
JCW Driver
Really?
I typed "stock wheel offset" in the search function and came up with a bunch of threads.
https://www.northamericanmotoring.co...archid=2954658
Old Jun 28, 2007 | 02:13 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks!
Justin
This thread moved from 1st generation MINIs interior/exterior to Tires, wheels and brakes forum.
Check the subject matter and post in the most appropriate forum when possible.
First when shopping check out tirerack.com or any of the vendors that sell wheels for the MINI and you will find 17" wheels of the correct size bolt pattern and offset.
To find the right wheels for you then you need to decide-
What suspension will you be using- stock or lowered- if so how much.
What tires are you going to match with the 17" wheels?
There are many discussions about what size wheels to use given different suspension upgrades or even with stock suspension.
17x7 to 17x8" is fine.
4x100 bolt pattern
Wheel offset about +38 to +48mm if using stock suspension
About +42 to +48mm is using lowered suspension (1" lower)
Watch out for clearance when using any big brake kit.
MINI hub bore is 56.1mm. Often aftermarket wheels use larger centerbore so centering rings are needed to make the wheels fit hubcentric (it's recommended). Some vendors provide the rings while others do not.
1010tires.com sells the rings in plastic or metal.
Old Jun 28, 2007 | 02:18 PM
old81's Avatar
old81
M6
Once again.
Minihune, that was a copy/paste and save post.
Minipooper2, you could save yourself a lot of searchs just by listing all the threads started or replied to my Minihune. Valuable information in multiple places, I admire his patience with us new folks.
Old Jun 28, 2007 | 05:52 PM
mikeo's Avatar
mikeo
The only thing I would add to minihune's excellent post would be try and keep the weight of the new wheels as low as your budget allows--definitely under 20lbs. for 17".
Old Jun 29, 2007 | 05:32 AM
minipooper02
4x100 bolt pattern
WOW...... Thanks!
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
