Whats up with this
Old Jun 27, 2007 | 02:01 PM
checkmate2006's Avatar
checkmate2006
Whats up with this
I can't get a picture on but i have it in my gallery of my driverside front tire.
what causes this problem
Alex
Old Jun 27, 2007 | 02:10 PM
Crusoe's Avatar
Crusoe
I saw this happen to my friend's MCS, the dealer said they ran it too long on low tire pressure which cause the stiff sidewalls of the runflats to apply pressure and wear the tread to a very focused area. He had Pirellis too.
Your tire is close to shreading to pieces.
Old Jun 27, 2007 | 02:15 PM
checkmate2006
Yeah i am getting rid of the runflats entirely and putting some BFG KDW2 215/40/17 because those pirellis SUCK i should have them this week HOPEFULLY
Old Jun 27, 2007 | 02:27 PM
Jenn B's Avatar
Jenn B
Check you alignment. How's the camber?
Old Jun 27, 2007 | 02:29 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Alex
Here it is-
You corded (wore down the rubber to the cords of the tire -Very bad)
the inner front edges of your tires.
Many reasons for this-
Bad alignment- check toe settings. Is it on both front tires?
Too much negative front camber- not likely
Defect in the tire- not likely if both front inner edges are like this.
Just alot of wear and worn to cords- looks like the rest of the tread is gone
You had the tires mounted with the worn side out but then remounted the tires to get more use out of them- called flipping tires- I did this on my current tires- worked well since outer edges get worn in the front so I put the right front tire on the left front wheel and vice versa, now my fresh tread is on the outer edges.
Old Jun 27, 2007 | 02:35 PM
checkmate2006
It is only driver side front that has this worn edge
Old Jun 27, 2007 | 07:34 PM
minihune's Avatar
minihune
Bad alignment
http://www.accidentreconstruction.co...s/tirewear.asp
Check camber angle or toe angle on that side but with alignment just get everything set to factory specs.
Old Jun 27, 2007 | 10:09 PM
moodylewdd's Avatar
moodylewdd
My Pirelli run flats are doing the same thing...inside both rear tires. I will be getting them replaced next month. The rest of the tread on them is around 25-30%. Wish I hadnt already replaced the front with new Pirelli runflats. I dont think I'll make that mistake again. Hey, anyone out there know what the factory specs are on alignments, or can push me in the right direction to finding it. Thanks in advance!
