smaller tires/speedo calibration question
Old Jun 19, 2007 | 02:06 PM
Sin MINI's Avatar
Sin MINI
Since I don't go fast but desire low end torque, I'm considering dropping from 17" to 16" tires. Howver, that means my speedo and odometer will read higher/farther than is the case.
Knowing that different style MINIs can come with different size tires, one would think MINI has a way to easily set the tire size in the speedo/odo to provide the correct readings. Is this true and can tis be adjusted to reflect a tire size change?
Old Jun 19, 2007 | 02:25 PM
kenchan's Avatar
kenchan
since you change the tire profile when you change the diameter of
the wheel you shouldn't need to recalibrate.
Old Jun 19, 2007 | 02:29 PM
kriation's Avatar
kriation
I use this tool all the time when trying to figure out tire/wheel ratios and what affect it will have on my speedo. Check it out here.
The tool is written in Java, so make sure you have the JRE plug-in for your browser.
Old Jun 19, 2007 | 02:34 PM
Eric_Rowland's Avatar
Eric_Rowland
OE 205/45-17 ~ 195/55-16 ~ 175/65-15
They are all roughly the same height.
There's no easy way that I know to change the speedo gearing.
Old Jun 19, 2007 | 02:43 PM
Sin MINI's Avatar
Sin MINI
Now I am confused. Folks in other threads kept talking about giong to smaller tires for better torque but speedo was off...now you're saying they are the same. My head is about to explode...
Old Jun 19, 2007 | 02:51 PM
Eric_Rowland
You CAN go to a smaller aspect ratio in a smaller tire - i.e. a 195/50-16 tire will be 2.5% smaller. A 195/45-16 is 5.6% smaller.
But just changing rim diameter doesn't automatically give you a smaller TIRE diameter.
I use this calculator
Old Jun 19, 2007 | 03:02 PM
Sin MINI's Avatar
Sin MINI
My bad...I wasn't clear. However, you will note I said smaller tires and not smaller wheels.
Old Jun 19, 2007 | 03:20 PM
Eric_Rowland
Actually, you said 17" tires to 16" tires. No mention of aspect ratio.
Old Jun 19, 2007 | 03:44 PM
rosmakloma's Avatar
rosmakloma
...same idea here:
So if I go from my 205/45/17's to a set of 185/65/15 winter tires/wheels - then I should have no issues?
thanks in advance!
Old Jun 19, 2007 | 03:52 PM
Eric_Rowland
Originally Posted by rosmakloma
...same idea here:
thanks in advance!
The new tire combo calculates out to .8% larger, so when your speedo reads 60, you'll be going 60.5.
Convention is to stay within 2% of the standard diameter, so you're set.
Old Jun 19, 2007 | 09:22 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Not really true, depends on which wheels and which tires.
If you want more responsive accleration and faster braking then select wheels and tires that weigh less and rubber that offers more grip and maybe larger contact patch within reason.
If you want the least speed/odo error then go with any tire size that is close to stock tire diameter of 24.4" or similar.
Smaller tire diameter helps to simulate lowered gearing and usually helps acceleration but may cause some speed error and may wear out the tread quicker.
17" wheels are 17x7 and tires are 205/45-17.
16" stock wheels are 16x6.5 and tires are 195/55-16.
Aftermarket wheels can be much lighter than stock wheels and tires can vary-
For 17" rims
215/40-17 is smaller than stock
215/45-17 and 225/45-17 are larger than stock
For 16" rims
205/50-16 is smaller than stock
205/55-16 is larger than stock
You cannot reset how your MINI displays speed and odo readings. You can use tires that are 1-3% from stock specs for the least variance and that is usually what we end up doing.
Old Jun 19, 2007 | 10:53 PM
Sin MINI's Avatar
Sin MINI
Thanks much!!
Old Jun 20, 2007 | 07:56 PM
90STX's Avatar
90STX
Or....you can get a Scangauge II or similar OBDII reader/display. One of the things that it can display is vehicle speed. It is the real ECM reading, not the "faster" value displayed on the speedometer. It can also be adjusted for different size tires, so you can see your real speed.
Scott
90SM
donniedarko
Oct 21, 2015 01:15 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
