Suspension 06 MCS rear camber range
Old Jun 16, 2007 | 07:58 PM
limster's Avatar
limster
I have a 06 MCS, its my understanding that the rear has a small amount of adjustabilitiy to the camber. Does anyone know how much adjustability there is and what that range is? I just had a 4 wheel alignment done on my car and the rear camber was 2.0/2.1 (left/right). I would expect that there is some variance in the range due to production tolorance.
TIA
Old Jun 17, 2007 | 10:13 AM
Fatherdeth's Avatar
Fatherdeth
TIA
I'd leave it as it is. The stock specs for the rear are minimum -2.0 degrees and the maximum is -1.0, so as you can see you are within the range.
As far as how much adjustability there is, I'm not sure.
Old Jun 18, 2007 | 06:21 AM
THE ITCH's Avatar
THE ITCH
Because of the rear trailing arm suspension the rear camber will change depending on how much weight is in the car. When a MINI dealer does an alignment their specs show a spring height range that the tech is suppose to achieve before doing the alignment. They do this by adding weight to the car. When I go to an independent alignment shop I prefer to be sitting in the car with a 1/2 tank of fuel. Comparing alignment specifications, especially rear camber, would change depending on how much weight is in the car.
Steve
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
