R56 vs R53 MINI S offset
Old Jun 13, 2007 | 02:05 PM
YseanY's Avatar
YseanY
I was wondering if any knew if the offset on the R56 and R53 are the same? I believe the later R53 use the 14mm bolts, same as the R56. So if i purchased a wheels for the R53 with 14mm bolts, it would fit the R56 correct? What about the offsets? Are they the same as well?
thanks!
Old Jun 13, 2007 | 07:02 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
thanks!
Yes, current 2007 MINIs have 14mm bolts and the same wheel offset as the latest 2006 MCS with 14mm bolts.
So lets say you go searching for wheels on tirerack and state it will be for an MCS built after May 2006 then it would be wheels that match and will also fit the 2007 R56 MINIs.
Old Jun 14, 2007 | 12:20 AM
YseanY's Avatar
YseanY
thanks!
Old Jun 17, 2007 | 05:26 PM
sandtoast500's Avatar
sandtoast500
Aren't the wheel wells a bit larger on the R56 allowing for wider wheels, such as 8", to run without any rubbing? They sure look like they're larger. . . zing!
I would go 17x8, if you can find it, et35-40.
Old Jun 20, 2007 | 12:12 PM
DrueDown's Avatar
DrueDown
So I have a R53 MCS built 6/6 & most sites do not ask the built before or after 5/6 question.
Does this mean I should be searching for wheels by selecting 2007 Mini Cooper S instead?
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
marendt428
Aug 8, 2015 04:44 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
