cant find 67.1 x 56.1 hub rings
these hub rings are really getting annoying.
tirerack doesnt have them.
1010tires show 67 x 56.1
but my rota slipstreams have a tag that says the bore is 67.1.
will the 67's from 1010 work?
if not where do i go?
thanks in advance
thanks in advance
Discount Tires fixed me up on my other car aftermarket rims (my new MINI rims came with the correct rings). Fortunately there is one here in town.They had the correct centering ring and fitted them for me. They are super to work with.
so i think i am suppose to go with a 1/100 less in diameter for fitment.
it doesnt make sense that everybody carries 67, and i cant find anybody with 67.1
im sure rota designed for standard rings, but well see.
I don't think that .1mm will make any difference. You probably won't even feel it when you fit the ring to the wheel.
Thread resurrection !!!!!!!!!
Anybody ever find a source for Aluminum 67.1 X 56.1mm rings?
You can find a polycarbonate set of 4 on Ebay for $10, and for street use that is fine, but for track use I am concerned about the melting point. Polycarbonate melts at ~512F, that might be a little on the low side for track use.
