ASA A1 info...
Old Jun 8, 2007 | 09:03 AM
brassknuckle's Avatar
brassknuckle
ASA A1 info...
Looking to upgrade MC wheels and like the ASA A1's (for a less pricey option than R99's) and was wondering if anyone who is running these can answer the following:
-do the rims mount flush with tires, that is, do the stick out more than stock rims where as they might easily get dinged while parking by scrapping the curb?
-are most of you running non-runflats with them?
-what does "offset" refer to when buying wheels(sorry if this is dumb one)
-any favorite tire choice, thinking of 17's , MC has stock 16 R83 on it now.
Thanks!
Old Jun 8, 2007 | 09:44 AM
CHKMINI's Avatar
CHKMINI
The run flats that I previously had mounted on my ASA's had the protective lip on the tire as do the non-runflats I have now so the rim is protected from mild curbing.
Old Jun 8, 2007 | 10:12 AM
camminich's Avatar
camminich
If you go with a 215 instead of a 205 you will also notice just a hair more cushion and rim protection. But as stated before, this is just mild.
The ASA AR1s are 42mm offset which does lie in safe area. Lowering and a wider tread tyre may cause a little light rubbing though. But if you went with a 215/45 R17 with normal heighth, you should be fine, and have that little bit of cush you are looking for.
Old Jun 8, 2007 | 01:39 PM
brassknuckle
Does anyone happen to have a photo of ARA A1's on MC ? I have searched around here and found a few snaps but wondering if anyone has pure silver MC with ARA A1 in silver. thank you.
Old Aug 27, 2007 | 09:51 PM
BRG's Avatar
BRG
try the MINI2.com web site. Go to the FAQ page where they have excellent information and pictures well organized. You will find a Cooper with ASA AR1's
Old Aug 27, 2007 | 11:39 PM
chuck r's Avatar
chuck r
This one been posted and looks awesome. 18" but I think you get the look.
chuck
Old Sep 25, 2007 | 05:06 AM
SuperMINIs's Avatar
SuperMINIs
What is the deal with buying after market wheels and using or not using run flats. Would they be compatible with the system on the 2007 Cooper S Cabrio using the runflats or not? I want to get snows and new rims. Thanks for your help.
Old Sep 25, 2007 | 05:16 AM
minimarks's Avatar
minimarks
How much do they weight in 17"?
Old Sep 25, 2007 | 06:33 AM
CARdiac's Avatar
CARdiac
Do the 17's clear any of the big brake kits?
Kimolaoha
Dec 5, 2020 09:32 PM
ebowling
90
Aug 4, 2019 09:15 AM
Alex@tirerack
Tires, Wheels, & Brakes
Oct 4, 2002 03:00 PM
Alex@tirerack
Oct 4, 2002 02:26 PM
