Suspension (-1.2 vs -2.1) Front Camber after Fixed camber plates?
Old Jun 4, 2007 | 02:12 PM
limster's Avatar
limster
Is it normal to have such a big difference after installing IE fixed camber plates? I understand that there will be a small amount of difference between the left and the right front camber coming out of the factory but it seems like a lot. I had the plates installed by one of the most reputable shops in the area and they did a alignment after they installed the camber plates. These number are about 2 months after I got the camber plates installed. The car has less than 3000 miles and I run 16" non-runflats. I have M7 SRPs since I first got the car and doesn't look as if I have mushrooming. Any ideas?
TIA
Old Jun 4, 2007 | 03:02 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The front subframe can be jockeyed from side to side after loosening the bolts to help equalize camber differences, but you might be reaching the limit on what can be done to zero out the difference. It's worth a try.
Old Jun 5, 2007 | 02:34 PM
meb's Avatar
meb
...proper air pressure? Dampers in the knuckle all the way? Ride height the same left right?
W0TM8
Dec 19, 2019 07:50 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
