R56 bugs in radiator.
Old May 23, 2007 | 09:30 AM
djam43's Avatar
djam43
bugs in radiator.
For you Mini owners who live in the south, this is Love-bug season. I was horrified to find that my radiator/aircondition condenser coils were about 50% plugged up with these mating suicidal wonders, after a weekend trip around Lake Okeechobee in Fla . This was not obvious from the outside of the car when I did my weekly wash. Unless you look real close it is easy to miss. To clean the coils you will have to remove the upper grille assembly. this is accomplished by removing the 4 plastic push plugs on the top of the grille assy. On the bottom chrome bar there are 2 latches ,one each side of this bar. When these are released this bar slides out . This exposes 4 latches on the bottom of this grille assy, unlatch these one at a time and you can remove the grille. I used a stiff brush to remove the critters. then washed with water. Failure to wash these could cause early failure of your coils due to the acids in their bodies which will attack metals and paint. Im sure that our northern friends also have similar seasonal problems with bugs.
Old May 23, 2007 | 09:49 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Gotta be realy careful brushing the radiator - very easy to bend the fins.
I GENTLY vacuum mine with the shop vac and the soft brush attachment... then wash with a soft microfiber mitt (not my wool mitt) as needed...
Old May 23, 2007 | 10:15 AM
DV8MINI's Avatar
DV8MINI
Prevention.......not Rehabilitation.
Here's what I do to my vehicles - Get some mesh screen at the hardware store, some welding wire and a pair of wire snips and fab up a "pre" screen in front of the radiator/condensor/intercooler/whatever. Just make sure to wire it down, but not to those parts. Every so often, you can brush off the screen and wash it off. Keeps everything behind it nice and clean.
Hope this works on the MCS without too much hassle.
Old May 23, 2007 | 10:22 AM
Loony2N's Avatar
Loony2N
Drive backwards
Old May 23, 2007 | 10:36 AM
djam43's Avatar
djam43
Your absolutely right, the radiator, which is the inner coil looks to be very fragile, fin wise, so be carefull. I used a small toothpick to remove the exposed bugs. The outer coil is the a/c unit which is a little more beefier still has to be handled with kid gloves when cleaning.
Old May 23, 2007 | 10:39 AM
djam43's Avatar
djam43
Good idea, I think that I will look into making some sort of removable inner screen that I can clean, as you suggested.
Old May 23, 2007 | 10:40 AM
MPowerMini's Avatar
MPowerMini
I was considering using a vacuum on the radiator to remove the dried bugs, do you think that this suction could in any way damage the radiator?
Old May 23, 2007 | 10:50 AM
djam43's Avatar
djam43
Well in my case the bugs wer dried/ cooked on , so I had to do some mechanical brushing with a small stiff bristle brush.(Toothbrush style) and then use a toothpick to remove the rest. Vacuum would not work in this situation.
Old May 23, 2007 | 02:02 PM
BlimeyCabrio
No way, no how.
If it sucks something loose that matters, you already had a bigger problem...
Old May 23, 2007 | 02:59 PM
4xAAA's Avatar
4xAAA
Good info! Thanks
Old May 23, 2007 | 04:32 PM
buzzsaw's Avatar
buzzsaw
I use a refrigerator coil brush--one of those long skinny types. The bristles are very soft and it's long enough to reach all of the condenser--works quite well. And it reqiures vey little effort.
Old May 24, 2007 | 09:08 AM
buzzsaw's Avatar
buzzsaw
I fabbed up the screen using heavy duty wire as the frame then bordered the frame and screen with metallic duct tape. Works like a champ. Thanks for the suggestion
Old May 24, 2007 | 09:16 AM
at7815's Avatar
at7815
OMG - I just looked closely at my radiator b/c of this thread, and what do ya know??? Of course I have about 100 lovebugs on there
I will be following the suggestions here. Thanks everyone sooo much for posting!
Ani
Old May 24, 2007 | 11:47 AM
DV8MINI's Avatar
DV8MINI
Ani
Thats a lot of lovemaking in your radiator...
Glad this "mod" works without hassle for you all. Now if I had mine, I'd know first hand..
Old May 24, 2007 | 12:13 PM
Morris9982's Avatar
Morris9982
One of the first things I used to do to a car when I bought it was to put a bug screen in front of the radiator.
Some companies used to sell a one size fits all screen. I never cared for them because they never fit right. I would go to a hardware store and buy some black fiberglass screen like the replacement screen wire for a screen door or your windows. Then I would take apart whatever was in the way and cut the screen to fit the front of the radiator and attach it in such a way that is was not readily visible.
This seemed to catch the bugs before they got into the radiator core and they would wash off (usually) with just a water hose.
Old May 24, 2007 | 12:52 PM
djam43's Avatar
djam43
Just checked with the hardware store , they sell "8 mesh " galvanized cloth. that is probably the size that you want to use as a pre filter. dont forget to check and clean it often.
Old May 24, 2007 | 05:17 PM
at7815's Avatar
at7815
This is so you guys can get an idea on how much of a lovebug heaven my front bumper was this weekend!!!! No wonder I have so many leftover in the radiator
Here's a pic. The good thing about it all was that the car had two layers of Z2 and the bugs all came off really easily, but the wash mitt didn't make it
Old Sep 5, 2007 | 12:13 PM
Pam's Avatar
Pam
Can anyone help me with how to get to the front of the radiator in order to install a screen? How do I take off the front grills on the '07 MCS?
Old Sep 5, 2007 | 05:22 PM
rockridge's Avatar
rockridge
Thanks for making me glad I live up north...
Old Sep 5, 2007 | 11:32 PM
ma78's Avatar
ma78
Coordinator :: Super Secret Orange County MINI Cooper Club
What's a lovebug????
Old Sep 5, 2007 | 11:56 PM
daffodildeb's Avatar
daffodildeb
It's a small black bug, looks sort of like a small lightening bug, that flies around attached to the missus. Absolutely zillions of them during lovebug season.
When we first arrived in Houston I was at a gas station, where I overheard a lady as the station owner "what's the purpose of these bugs?" The owner contemplated the lady a bit, then answered "well, I guess it's to make MORE lovebugs..." in a true Texas drawl. Great answer!
Old Sep 6, 2007 | 02:34 AM
Silverbullit's Avatar
Silverbullit
I think I want to come back as a "Love Bug"!! You go out in a blaze of glory!!
Old Sep 6, 2007 | 04:20 AM
glangford's Avatar
glangford
Where did you get a refrigerator coil brush??
Old Sep 6, 2007 | 05:17 AM
Madoc's Avatar
Madoc
Love bug portrait here...
What was the miracle product you used to make them come off easier?
Old Sep 6, 2007 | 05:51 AM
Minidrivr's Avatar
Minidrivr
Try a bug guard.
http://www.bugguardsforbeemers.com/mini.shtml
I have something similar on my streetbike radiator.
